no space on device (64GB USB BOOT)
sharpusa
So freenas has been working fine, my volume1 has 10TB (connected to client machine via iSCSI)
Freenas is on a fast 64GB USB. System is an Intel XEON CPU with 16GB RAM ECC. Storing only backups.
After scrub started I ran out of space, I even updated to the latest freenas last night, rebooted, still out of space.
Attached is a log message.
___________
Filesystem Size Used Avail Capacity Mounted on
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502070132 55G 935M 54G 2% /
devfs 1.0k 1.0k 0B 100% /dev
tmpfs 32M 5.3M 26M 17% /etc
tmpfs 4.0M 8.0k 4M 0% /mnt
tmpfs 5.3G 35M 5.3G 1% /var
freenas-boot/grub 54G 7.8M 54G 0% /boot/grub
volume1 170k 170k 0B 100% /mnt/volume1
volume1/.system 738k 738k 0B 100% /var/db/system
volume1/.system/cores 1.5M 1.5M 0B 100% /var/db/system/cores
volume1/.system/samba4 184k 184k 0B 100% /var/db/system/samba4
volume1/.system/syslog-f36704f2fe794cb6a75657843255655d 568k 568k 0B 100% /var/db/system/syslog-f36704f2fe794cb6a75657843255655d
volume1/.system/rrd-f36704f2fe794cb6a75657843255655d 170k 170k 0B 100% /var/db/system/rrd-f36704f2fe794cb6a75657843255655d
_________________
Thanks,
Charles
  • freenas_log.txt
S
sef
Guest
Your data pool -- volume1 -- is 100% full. You need to either free up space, or add more storage.
sharpusa
Will I provisioned to use 10T when I originally setup freenas, and I do have 7TB available on the iscsi map.
pirateghost
Unintelligible Geek
So you allocated 100% of your volume to iscsi?
And you wonder where your space went?
sharpusa
How much space would I need free for Freenas? I was assuming the 64GB USB is were the logs will be storing on, not on the actual volume1 where I store my backups.
pirateghost
Unintelligible Geek
Well all the warnings and documentation indicate you shouldn't let your pool get more than 80% full....
So you allocated 100% of your volume to iscsi which is full allocation and not thin provisioned which means you filled the pool/volume regardless of what your iscsi disk shows available.
As the documentation states, freenas makes a .system volume for storing logs...
sharpusa
You are right, I'm trying to reduce the size from 10T to 9.5T, but doesn't do anything, do I have to delete the volume and start again?
You were assuming incorrectly. The logs and other related data are stored in the .system dataset, which goes on whatever pool you configure in the web GUI. By default, it goes on the first data pool you create. I don't know if it can be placed on the boot pool at all (though I'd discourage it--lots of r/w activity is not good on USB sticks), but that certainly isn't the default.
You will have to delete the iSCSI zvol/file and recreate it as a smaller size. But it should be only 50% of the total size of the pool (so about 5TB) maximum for performance reasons.
