ajschot
- Nov 7, 2016
here it isI did but can't remember if it was something I fixed or an update fixed.
Can you post ifconfig from root? It may be an issues with the interface not connected to the bridge.
[root@freenas ~]# ifconfig
vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=200099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,RXCSUM_IPV6>
ether 00:0c:29:bf:a4:4f
hwaddr 00:0c:29:bf:a4:4f
inet 192.168.178.25 netmask 0xffffff00 broadcast 192.168.178.255
inet6 fe80::20c:29ff:febf:a44f%v[root@freenas ~]# ifconfig
inet6 fe80::20c:29ff:febf:a44f%vmx0 prefixlen 64 scopeid 0x1
inet6 2001:981:4a70:1:20c:29ff:febf:a44f prefixlen 64 autoconf
inet6 fd00::1:20c:29ff:febf:a44f prefixlen 64 detached autoconf
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
media: Ethernet autoselect
status: active
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
ether 02:df:c7:34:6e:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vnet0:13 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
member: vnet0:5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: vmx0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 2000
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: transmission
options=8<VLAN_MTU>
ether a2:ec:2a:7d:3b:b2
hwaddr 02:7d:d0:00:05:0a
status: active
groups: epair
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex
options=8<VLAN_MTU>
ether 02:ff:60:24:fa:09
hwaddr 02:7d:d0:00:06:0a
status: active
groups: epair
vnet0:5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: couchpotato
options=8<VLAN_MTU>
ether 02:ff:60:1c:24:41
hwaddr 02:7d:d0:00:08:0a
status: active
groups: epair
vnet0:13: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: NZBget
options=8<VLAN_MTU>
ether 02:ff:60:b8:86:30
hwaddr 02:7d:d0:00:04:0a
status: active
groups: epairmx0 prefixlen 64 scopeid 0x1
status: active
groups: lo
groups: bridge
member: vnet0:12 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
vnet0:12: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
status: active
groups: epair
[root@freenas ~]#[root@freenas ~]# ifconfig
status: active
groups: lo
groups: bridge
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
options=8<VLAN_MTU>
status: active
groups: epair
