Writing this one up as I had some trouble when migrating Plex and thanks to @sretalla helping me with Plex and @Pentaflake having written an excellent thread on jails, I wanted to have a quick resource for anyone looking on what and how to move to an iocage jail.
https://forums.freenas.org/index.ph...lidarr-jackett-ombi-transmission-organizr.58/ was where most of the setup came from.
#Create jail and install Tautulli
#Stop the jail to move your db into it
iocage exec tautulli service tautulli stop
#Old filepath for reference
#Copy your tautulli.db file over, and nothing else into the newly create config folder for your jail.
Start Tautulli, login to plex and all should be there. Shut down your old jail and delete it!
echo '{"pkgs":["python2","py27-sqlite3","py27-openssl","ca_root_nss","git"]}' > /tmp/pkg.json
iocage create -n "tautulli" -p /tmp/pkg.json -r 11.1-RELEASE ip4_addr="vnet0|192.168.1.3/24" defaultrouter="192.168.1.1" vnet="on" allow_raw_sockets="1" boot="on"
rm /tmp/pkg.json
mkdir /mnt/jailssd/apps/tautulli
iocage fstab -a tautulli /mnt/jailssd/apps/tautulli /config nullfs rw 0 0
iocage exec tautulli git clone https://github.com/Tautulli/Tautulli.git /usr/local/share/Tautulli
iocage exec tautulli "pw user add tautulli -c tautulli -u 109 -d /nonexistent -s /usr/bin/nologin"
iocage exec tautulli chown -R tautulli:tautulli /usr/local/share/Tautulli /config
iocage exec tautulli cp /usr/local/share/Tautulli/init-scripts/init.freenas /usr/local/etc/rc.d/tautulli
iocage exec tautulli chmod u+x /usr/local/etc/rc.d/tautulli
iocage exec tautulli sysrc "tautulli_enable=YES"
iocage exec tautulli sysrc "tautulli_flags=--datadir /config"
iocage exec tautulli service tautulli start
/mnt/jailssd/PlexPy/usr/local/share/plexpy/
cp -f -i "/mnt/jailssd/PlexPy/usr/local/share/plexpy/tautulli.db" "/mnt/jailssd/apps/tautulli"
