No network connection in Plex jail
Lukas
So, I freshly installed the Plex plugin from scratch a few days ago. When I was setting up the Plex settings for the first time, everything seemd fine. But when I returned a few hours later to sign in to my MyPlex account and add additional media, the Plex server GUI didn't load. I started further investigating the issue and ssh'ed into the jail and noticed I didn't get any connectivity to the outside except for my router and my FreeNAS host.
When I look at the Plex Media Server logs I see many of these messages:
Mar 16, 2014 13:52:33 [0x807782000] ERROR - Error issuing curl_easy_perform(handle): 6
Mar 16, 2014 13:52:33 [0x807782000] WARN - Error issuing request to: http://www.plexapp.com/plex/blacklisted/2167b3f (6, Couldn't resolve host name) (Couldn't resolve host 'www.plexapp.com')
So, I checked if the jail has a default gateway and this is the output of my netstat -rn:
Routing tables
Internet:
Destination        Gateway            Flags    Refs      Use  Netif Expire
default            192.168.0.1        UGS         0     9823 epair1
127.0.0.1          link#1             UH          0     8783    lo0
192.168.0.0/24     link#2             U           0    42240 epair1
192.168.0.201      link#2             UHS         0    24072    lo0
Internet6:
Destination                       Gateway                       Flags      Netif
 Expire
::/96                             ::1                           UGRS        lo0
::1                               link#1                        UH          lo0
::ffff:0.0.0.0/96                 ::1                           UGRS        lo0
fe80::/10                         ::1                           UGRS        lo0
fe80::%lo0/64                     link#1                        U           lo0
fe80::1%lo0                       link#1                        UHS         lo0
ff01::%lo0/32                     ::1                           U           lo0
ff02::/16                         ::1                           UGRS        lo0
ff02::%lo0/32                     ::1                           U           lo0
I have been searching for a solution to this for several hours now and have no more ideas on what to try. Can someone help me?
Can you post the stuff that's requested in the forum rules?
Lukas
Ah, yes. Of course.
FreeNAS version: 9.2.1.2 (64bit)
Running on a HP N40L with 8GB of RAM
DMESG output
bridge0: Ethernet address: 02:70:68:39:f4:00
bge0: promiscuous mode enabled
bridge0: link state changed to UP
epair0a: Ethernet address: 02:90:f7:00:0b:0a
epair0b: Ethernet address: 02:90:f7:00:0c:0b
epair0a: link state changed to UP
epair0b: link state changed to UP
epair0a: promiscuous mode enabled
epair1a: Ethernet address: 02:67:72:00:0c:0a
epair1b: Ethernet address: 02:67:72:00:0d:0b
epair1a: link state changed to UP
epair1b: link state changed to UP
epair1a: promiscuous mode enabled
arp: 24:65:11:24:f6:48 is using my IP address 192.168.0.201 on epair1b!
epair2a: Ethernet address: 02:6a:72:00:0d:0a
epair2b: Ethernet address: 02:6a:72:00:0e:0b
epair2a: link state changed to UP
epair2b: link state changed to UP
epair2a: promiscuous mode enabled
epair3a: Ethernet address: 02:40:94:00:0e:0a
epair3b: Ethernet address: 02:40:94:00:0f:0b
epair3a: link state changed to UP
epair3b: link state changed to UP
epair3a: promiscuous mode enabled
IFCONFIG output of host:
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
    ether a0:b3:cc:eb:0b:1e
    inet 192.168.0.42 netmask 0xffffff00 broadcast 192.168.0.255
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
    options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9
    ether 02:70:68:39:f4:00
    nd6 options=1<PERFORMNUD>
    member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 14 priority 128 path cost 2000
    member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 13 priority 128 path cost 2000
    member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 12 priority 128 path cost 2000
    member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 11 priority 128 path cost 2000
    member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:90:f7:00:0b:0a
    status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:67:72:00:0c:0a
    status: active
epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:6a:72:00:0d:0a
    status: active
epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:40:94:00:0e:0a
    status: active
Jail:
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair1b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:0a:09:00:0f:0b
    inet 192.168.0.201 netmask 0xffffff00 broadcast 192.168.0.255
    status: active
Did I forget anything?
D
dlavigne
Guest
Is there a DNS server in the network? If so, is it's IP address set in Network -> Global Configuration?
Lukas
Yes, the DNS server is set. Also, ping to a public ip adress e.g. 8.8.8.8 doesn't work from inside the jail.
Lukas
Very interesting. Your idea worked perfectly well for fixing the reachability issue of the web interface. Thank you!
But still, I can't get any kind of internet connection from within the jail :(
