no network connection between jail and network outside the truenas
i have used the plugin Zabbix in Truenas. After that I switched to Jails and did the network settings.
Zabbix, Truenas and the ESXi server running Truenas are all on the same network segment. From Zabbix Truenas is pingable, but not the ESXi server. An incorrect setting in the network settings can be ruled out. Does anyone have any advice ?
Thank you
Patrick M. Hausen
You are using a VNET jail and you did the required bridge setup?
