enry
- Apr 10, 2016
Well I might have gotten myself into a bit of a pickle....
My USB was dying according to FreeNAS, so I grabbed the latest image and installed it. Unfortunately, I think the old USB was running 9.3 and the new one is running 9.10. After installing 9.10 and uploading the 9.3 config, the jails are starting, but I can't see them in the jails tab across the top, but I do see them in the list of jails on the left side, so I can see the configuration but I can't delete them.
Even if I could delete the jails, I can't install new ones. The list of plugins won't update. Click update, nothing. I confirmed I have network connectivity:
[root@debbie] ~# wget http://download.freenas.org/plugins/9/x64/pbi-meta/pbi-repo.rpo
--2016-04-10 22:07:32-- http://download.freenas.org/plugins/9/x64/pbi-meta/pbi-repo.rpo
Resolving download.freenas.org (download.freenas.org)... 209.51.186.11
Connecting to download.freenas.org (download.freenas.org)|209.51.186.11|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 939 [application/octet-stream]
Saving to: 'pbi-repo.rpo'
pbi-repo.rpo 100%[===============================================================>] 939 --.-KB/s in 0s
2016-04-10 22:07:34 (122 MB/s) - 'pbi-repo.rpo' saved [939/939]
[root@debbie] ~#
[root@debbie] ~#
