IvanVolkov
- Dec 21, 2021
I changed NIC (another MAC and IP address) and Cloud Sync stopped working.
If I put back old NIC so Cloud Sync works perfectly.
Also I tried to create new Cloud Credentials with new NIC but it don't works but I have success with ones on old NIC.
Please help me to fix this issue
Version: TrueNAS-12.0-U7
CallError (Dropbox)
[EFAULT] 2021/12/21 12:55:00 Failed to create file system for "remote:/": get current account failed: Post "https://api.dropboxapi.com/2/users/get_current_account": dial tcp: lookup api.dropboxapi.com on [::1]:53: read udp [::1]:26407->[::1]:53: read: connection refusedCallError (Google Drive)
[EFAULT] 2021/12/21 12:57:55 ERROR : : error listing: couldn't list directory: Get "https://www.googleapis.com/drive/v3...nd+('root'+in+parents)&supportsAllDrives=true": couldn't fetch token - maybe it has expired? - refresh with "rclone config reconnect remote:": Post "https://oauth2.googleapis.com/token": dial tcp: lookup oauth2.googleapis.com on [::1]:53: read udp [::1]:38894->[::1]:53: read: connection refused 2021/12/21 12:57:55 Failed to lsjson with 2 errors: last error was: error in ListJSON: couldn't list directory: Get "https://www.googleapis.com/drive/v3...nd+('root'+in+parents)&supportsAllDrives=true": couldn't fetch token - maybe it has expired? - refresh with "rclone config reconnect remote:": Post "https://oauth2.googleapis.com/token": dial tcp: lookup oauth2.googleapis.com on [::1]:53: read udp [::1]:38894->[::1]:53: read: connection refusedIf I put back old NIC so Cloud Sync works perfectly.
