Help with Azure storage backup
Morpheus0800
Hi there...I've found a few topics about adding Azure blob storage but nothing led me to some solution.
After setting up den Azure blob storage an copying the account name and the key into the credential, following error appear:
Error: 2020/09/19 14:29:13 ERROR : : error listing: -> github.com/Azure/azure-pipeline-go/pipeline.NewError, /wrkdirs/usr/ports/net/rclone/work/rclone-1.50.2/vendor/github.com/Azure/azure-pipeline-go/pipeline/error.go:154
HTTP request failed
Get https://azurefreenasbackup.blob.core.windows.net?comp=list&maxresults=5000&timeout=31536001: dial tcp: lookup azurefreenasbackup.blob.core.windows.net on [::1]:53: read udp [::1]:26248->[::1]:53: read: connection refused
2020/09/19 14:29:13 Failed to lsjson with 2 errors: last error was: error in ListJSON: -> github.com/Azure/azure-pipeline-go/pipeline.NewError, /wrkdirs/usr/ports/net/rclone/work/rclone-1.50.2/vendor/github.com/Azure/azure-pipeline-go/pipeline/error.go:154
HTTP request failed
Could please somebody explaine to me what the problem could be?
Thanks a lot in advance!
Morpheus0800
#solved
put the nameserver into the general setup of freenas.
Then, updated the timezone because an error of different times on the freenas server and on Azure occured
...finally it works!
