well as it says... It worked perfectly in 9.2.0 and now it doesn't. Basically Iv found that if I restart the service do..
mount -t nfs 192.168.x.x:/mnt/tank/media /mnt/media -otcp,vers=3
right after I restart the service I can connect, it takes longer then it should, however if I unmount and try to remount with the same command it will not remount.
the -v option posts this.
$ sudo mount -v -t nfs 192.168.x.x:/mnt/tank/media /mnt/media -otcp,vers=3
mount.nfs: timeout set for Thu Feb 13 13:06:14 2014
mount.nfs: trying text-based options 'tcp,vers=3,addr=192.168.1.18'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: trying 192.168.1.18 prog 100003 vers 3 prot TCP port 2049
mount.nfs: prog 100005, trying vers=3, prot=6
mount.nfs: trying 192.168.1.18 prog 100005 vers 3 prot TCP port 737
mount.nfs: portmap query failed: RPC: Timed out
before the upgrade I would just do
and it would mount extremely quickly without any issues but that will no longer work at all.
Edit: I just tried waiting some time and trying to mount it and it mounted on the first time but then its like there is a lockout for mounting again. I cant mount because it just keeps timing out after.
