nfs mount subdirectory
07stuntar1
How do a mount a subdirectory on an NFS share. Right now its Truenas/mnt/Storage
The program I am using doesn't allow mounting subdirectories. But I don't want to write to /mnt
Anyway to make map directly to Storage. SMB works because it doesn't use the long path.
Seems to be the problem here... change that to something that makes sense (and doesn't introduce non-existent problems into the equation).
if you're using NFS, you need to work with how NFS works... if the program expects to be using SMB, then use SMB.
