Been using FreeNAS for over 5 years and decided to finally upgrade to new TrueNAS core in December. Since then, users have reported NFS related errors, mainly related to applications needing to lock a NFS file (e.g. gnupg, libreoffice)
After some troubleshooting, it seems lockd is not starting properly on reboot or is terminating after a reboot. rpcinfo -p returns the following:
The lockd process does appear to be running, but nlockmgr is just not being serviced.
Performing a manual restart directly from GUI fixes the nlockmgr service, but the slider icon just spins indefinitely as if the restart did not complete cleanly (see image)
Not seeing any logs as to why this is happening. Note, I was running FreeNAS 11.2-U7 prior to upgrading and never encountered this issue.
No hardware changes whatsoever. Only updated to TrueNAS 12-U1
Be happy to provide any logs, outputs, etc... Any assistance would be appreciated. Thanks
Specs:
Gigabyte Z97N-WIFI
Intel(R) Core(TM) i7-4765T CPU @ 2.00GHz
16GB DDR3 1333Mhz RAM
Intel Pro Gigabit NIC (onboard)
Chelsio T440-CR 10Gb Card
rpcinfo -p program vers proto port service 100000 4 tcp 111 portmapper 100000 3 tcp 111 portmapper 100000 2 tcp 111 portmapper 100000 4 udp 111 portmapper 100000 3 udp 111 portmapper 100000 2 udp 111 portmapper 100000 4 7 111 portmapper 100000 3 7 111 portmapper 100000 2 7 111 portmapper 100005 1 udp 987 mountd 100005 3 udp 987 mountd 100005 1 tcp 987 mountd 100005 3 tcp 987 mountd 100003 2 tcp 2049 nfs 100003 3 tcp 2049 nfs 100024 1 udp 888 status 100024 1 tcp 888 status
root 3356 0.0 0.0 17336 4324 - Ss 22:08 0:00.00 /usr/sbin/rpc.lockd -d 10
Specs:
Gigabyte Z97N-WIFI
