I had a power outage today and after the FreeNAS server came back online my NFS share was inaccessible. The webgui continues to work and I can ssh into the server no problem. I can also access the server via AFP and CIFs without any issues, it only seems to be related to NFS. I do not know what could have changed, the server at previous times has been rebooted without affecting the shares in any negative way.
I have tried deleting the NFS share and re-adding it again, and can do a showmount for 30 seconds or so before it stops working. Restarting NFS also has the same effect
From the connecting machine
Any help in figuring out what has gone wrong will be greatly appreciated.
Thanks.
[root@magneto] ~# showmount -e RPC: Timed out showmount: can't do exports rpc [root@magneto] ~# service rpcbind forcestatus rpcbind is running as pid 2034. [root@magneto] ~# service nfsd forcestatus nfsd is running as pid 6108 6109.
[root@magneto] ~# showmount -e Exports list on localhost: /mnt/space 192.168.0.0
root@eleanor:~$ rpcinfo -p 192.168.0.20 program vers proto port service 100000 4 tcp 111 portmapper 100000 3 tcp 111 portmapper 100000 2 tcp 111 portmapper 100000 4 udp 111 portmapper 100000 3 udp 111 portmapper 100000 2 udp 111 portmapper 100000 4 7 111 portmapper 100000 3 7 111 portmapper 100000 2 7 111 portmapper 100003 2 udp 2049 nfs 100003 3 udp 2049 nfs 100003 2 tcp 2049 nfs 100003 3 tcp 2049 nfs 100024 1 udp 670 status 100024 1 tcp 670 status 100021 0 udp 661 nlockmgr 100021 0 tcp 951 nlockmgr 100021 1 udp 661 nlockmgr 100021 1 tcp 951 nlockmgr 100021 3 udp 661 nlockmgr 100021 3 tcp 951 nlockmgr 100021 4 udp 661 nlockmgr 100021 4 tcp 951 nlockmgr 100005 1 udp 1015 mountd 100005 3 udp 1015 mountd 100005 1 tcp 1015 mountd 100005 3 tcp 1015 mountd
Thanks.
