FreeNASftw
- Mar 1, 2015
I've installed the NextCloud plugin and all the file sharing side of things appears to work very well.
I have found many mentions on line of apps for contacts and calendar however these don't appear in the apps list from the plugin, is this normal? Perhaps the apps are removed as the functionality has been moved to the core?
I'm also trying to sync contacts & calendar using card/calDAV and it seems to work on my Android phone, however I can't connect from the Evolution mail client under Ubuntu 16.04 LTS.
The error is "Method not allowed" or alternatively "PROPFIND on webdav failed with HTTP status 405 (Method Not Allowed)" if I close Evolution, reopen it, then refresh the contact list.
The same errors occur when attempting to use calDAV.
Cheers
Cheers
