I took the plunge and upgraded from FN 11.1-U6 to 11.2 release. I have not sealed the deal by upgrading the ZFS pool (don't know if it is needed for my issue).
Since then my preexisting Nextcloud warden jail (via plugin) stopped having access to the SMB shares that I previously set up (working prior to upgrade). I noticed this after I tried the following in sequence which all failed to provide results:
Why doesn't the plugin install smbclient?
Did FN 11.2 disable the smbclient? If so, why?
Or did Nextcloud 14 disable it? If so, why?
My preferred solution is to get #1 (Nextcloud 14 plugin) to work but I have no idea how to get the appropriate smbclient along with the matching php-smbclient via the appropriate installer to work. I tried one installer, but it did not work.
Any help or insight is much appreciated.
- Adding a Nextcloud 14 plugin in 11.2 (iocage flavor). No smbclient installed. I have no idea how to install it either. Web and form search turned up conflicting suggestions which were dated or not fully applicable.
- Creating a Nextcloud 14 iocage jail via danb35's cool script. At the end of install I cannot get the web interface to work.
