Hi!
I'm trying to get my backup-server switched to TrueNAS using Scale 23.10.1.3.
Doing so, I do have the first two things, that I cannot figure out...
#1 nfs-share permissions
For testing I added the first nfs-share with the owners nobody:users and permissions set to '777'. The allowed network is set to a /24 netmask.
In my understanding, the share is completely open for everybody on the defined network.
- I can mount the share at my 'main-server'
- Copying the first folder (using 'mc') the folder is created but midnight commander shows an error that the chown-command fails.
- The same happens copying some files.
=> Why is this happening, having the share open with 777-permissions!?
#2 encryption keys storage
I don't like having the keys stored on the server. In a first step I would like to have them at an usb-stick and later on at a network-drive. To my surprise this is not possible. I have to use the enterprise-license to get this done (kmip).
Thinking about it, I can have an usb-stick mounted at boot and a softlink to the keyfile on it. Is this a proper solution? Are there other better options and some howtos to know what to do, to not destroy the server doing it?
I kindly appreciate your help.
Kind regards,
tom
Kind regards,
tom
