Newbie and Fstab
rjcb
I am starting with TrueNas and I don't understand why my fstab comes back to the initial config at each reboot.
For exemple:
I set:
/dev/da1p1 /mnt/diskint ufs rw 0 0 0
When I reboot only the default line remains:
fdescfs /dev/fd fdescfs rw 0 0
Config at the CLI is potentially going to be overwritten... as you are told every time you open the CLI.
Welcome to TrueNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
If you want that change to be there on every boot, you need to script it with sed or similar and run that script as a post-init.
rjcb
Thanks for the quick reply. I just need to add a new hard disk with a mount point :)
Patrick M. Hausen
To add to @jgreco's post - ZFS is the only file system supported for storage in TrueNAS. Even if you manage to add a UFS filesystem like in your fstab entry, you will not be able to use it for any services.
jgreco
Resident Grinch
That might not be strictly true; NFS, for example, would probably work, but I expect there would be problems with SMB because of all the ZFS- and iX-specific module work done by @anodos ... however, it is certainly skeezy and also risky to have disks attached that the middleware does not understand.
Patrick M. Hausen
As far as I know the middleware prohibits configuring any share on anything but a configured ZFS pool. I'm not 100% confident I am correct.
jgreco
Resident Grinch
You are certainly correct in that it attempts to do so. But it is a weak willed error prone attempt; it is happy to accept a non-ZFS submountpoint.
root@nas0:/mnt/storage0 # mkdir shareme
root@nas0:/mnt/storage0 # mount -t tmpfs tmpfs /mnt/storage0/shareme
root@nas0:/mnt/storage0 # df shareme
Filesystem 1K-blocks Used   Avail Capacity  Mounted on
tmpfs        3964904    4 3964900     0%    /mnt/storage0/shareme
Then go to webUI and share that via NFS
root@nas0:/mnt/storage0 # grep shareme /etc/exports
Ta da, non-ZFS share shared. We worked this out at some point for a fellow who wanted iSCSI file extents on UFS, which definitely works (or at least worked). I would not expect this to work for SMB due to all the ZFS-specific stuff.
rjcb
Ok, thanks for the replies. So I did that so far:
I created one pool with on disk (I know the risk).
My need is to:
Backup my data form my cloud subscription to my local hard disk in a folder named pcloud
Backup my data from my laptop to my local hard disk in a folder named laptop
Is that possible ?
Many Thanks
using a cloud sync task (based on having created a cloud credential first)
Many ways to do that, but SMB share and using Windows backup to point at that share is the one that's already there.
Is that possible ?
Yes, see above, maybe create a dataset for each of those if you would like to have different snapshot frequencies, permissions, recordsizes or otherwise keep the data separate.
rjcb
Now am able to share with NFS et SMB. I have just another question.
I have installed the plugin Motion and I want to save the record in a specific folder: /mnt/diskint/camera but doesn't work.
However in /mnt it works, I do not understand why :-/
rjcb
Ok in looking deeper, I found that I need to create a Jail what I've done so and mount a point, but :
I want that my record from camera goes to /mnt/diskint/camera so I need to select the below source and select the default folder of records in MotionEye (/var/lib/motioneye/ but I don't find the path in the below destination.
There's nothing wrong with typing a path if you know it's there or you want it to be created.
rjcb
Thanks. To be honest I do not understand ... and my need seems easy, at least on Linux OS.
I would like that the path of my records of my cameras is /mnt/diskint/camera.
But it doesn't work when I try to do it via Jails to mount points.
When I try to set the path /mnt/diskint/camera and I save it shows
/mnt/diskint/iocage/jails/camerafolder/root/mnt/diskint/camera
Looks to me like you have it backwards... hence not working.
Source is /mnt/diskint/camera
Destination is /mnt/diskint/iocage/jails/wheteverJailRunsMotionEye/root/var/lib/motioneye
You need to think of jail mounts as mounting storage into the jail, not the other way around.
rjcb
Ok, so I try to progress :)
I did that :
but my records are in mnt/diskint/iocage/jails/Portier/root/var/lib/motioneye and when I set this path in the first screen it doesn't take it :(
OK, I see what's happening... you're trying to add a mount to the wrong jail (you're in camerafolder when trying to add that mount).
