SOLVED New replication task is not starting
pechkin000
I have my main server set up with just one volume with 2 datsets on it set to do recursive snapshot as well as my new backup server with one dataset on it specifically for receiving replicated snapshots . I followed the instructions from http://doc.freenas.org/index.php/Replication_Tasks to a tee and everything seemed to work, the push server found the remote key from Pull. I am attaching what my task looks like on Push.
I was under impression that once the task is created, initial replication task should start immediately. I am at a loss as to what I did wrong or where to check what the problem may be. One thing, the dataset on Pull is shared via CIFS, is that a problem? The /var/run/autorepl.pid does not exist, so obvious initial replication is not happening. I have roughly around 3tb of data on push to be replicated. I ran
ssh -vv -i /data/ssh/replication hostname_or_ip
so here iw what I got:
[root@freenas] ~# ssh -vv -i /data/ssh/replication 192.168.192.77
OpenSSH_6.2p2, OpenSSL 0.9.8za-freebsd 5 Jun 2014
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to 192.168.192.77 [192.168.192.77] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /data/ssh/replication type 1
debug1: identity file /data/ssh/replication-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.2_hpn13v11 FreeBSD-20130515
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.2_hpn13v11 FreeBSD-20130515
debug1: match: OpenSSH_6.2_hpn13v11 FreeBSD-20130515 pat OpenSSH*
debug2: fd 4 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa,ssh-dss-cert-v01@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se,none
debug1: AUTH STATE is 0
debug2: mac_setup: found hmac-md5-etm@openssh.com
debug1: REQUESTED ENC.NAME is 'aes128-ctr'
debug1: kex: server->client aes128-ctr hmac-md5-etm@openssh.com none
debug1: kex: client->server aes128-ctr hmac-md5-etm@openssh.com none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA bb:6a:75:5a:40:e2:8f:2d:f9:ef:80:ad:ac:3b:76:da
debug1: Host '192.168.192.77' is known and matches the ECDSA host key.
debug1: Found key in /etc/ssh/ssh_known_hosts:2
debug1: ssh_ecdsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /data/ssh/replication (0x80288f100), explicit
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /data/ssh/replication
debug2: we sent a publickey packet, wait for reply
debug1: Server accepts key: pkalg ssh-rsa blen 279
debug2: input_userauth_pk_ok: fp f2:f8:5c:9e:38:ae:cb:ed:23:0c:96:dd:25:db:76:a8
debug1: read PEM private key done: type RSA
debug1: Authentication succeeded (publickey).
Authenticated to 192.168.192.77 ([192.168.192.77]:22).
debug1: Final hpn_buffer_size = 2097152
debug1: HPN Disabled: 0, HPN Buffer Size: 2097152
debug1: channel 0: new [client-session]
debug1: Enabled Dynamic Window Scaling
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug2: callback start
debug2: fd 4 setting TCP_NODELAY
debug2: client_session2_setup: id 0
debug2: channel 0: request pty-req confirm 1
debug2: channel 0: request shell confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: tcpwinsz: 66608 for connection: 4
debug2: channel_input_status_confirm: type 99 id 0
debug2: PTY allocation request accepted on channel 0
debug2: channel 0: rcvd adjust 65536
debug2: shell request accepted on channel 0
Last login: Tue Aug 26 11:49:48 2014 from 192.168.192.54
FreeBSD 9.2-RELEASE-p10 (FREENAS.amd64) #0 r262572+4fb5adc: Wed Aug  6 17:07:16 PDT 2014
        FreeNAS (c) 2009-2014, The FreeNAS Development Team
        All rights reserved.
        FreeNAS is released under the modified BSD license.
        For more information, documentation, help or support, go here:
        http://freenas.org
Welcome to the REPLICATOR
[root@replicator] ~# debug2: tcpwinsz: 66608 for connection: 4
sshdebug2: tcpwinsz: 66608 for connection: 4
-vdebug2: tcpwinsz: 66608 for connection: 4
v -debug2: tcpwinsz: 66608 for connection: 4
i /debug2: tcpwinsz: 66608 for connection: 4
dadebug2: tcpwinsz: 66608 for connection: 4
ta/debug2: tcpwinsz: 66608 for connection: 4
/rdebug2: tcpwinsz: 66608 for connection: 4
epldebug2: tcpwinsz: 66608 for connection: 4
icadebug2: tcpwinsz: 66608 for connection: 4
tiodebug2: tcpwinsz: 66608 for connection: 4
ndebug2: tcpwinsz: 66608 for connection: 4
debug1: client_input_channel_req: channel 0 rtype keepalive@openssh.com reply 1
pechkin000
IN case anyone is interested, checking Initialize Remote Side for Once resolved this issue
