Crashplan headless to Raspberry pi linux
Halfe
I'm getting frustrated.
I have been trying to install Crashplan backup on my NAS for ages and im now stuck at this (at bottom)
root@SYSTEM:/ # ssh -L 4200:127.0.0.1:4243 crashplan@10.0.2.6 -N -v -v
OpenSSH_5.8p2 FreeBSD-20110503, OpenSSL 0.9.8x 10 May 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: ssh_connect: needpriv 0
debug1: Connecting to 10.0.2.6 [10.0.2.6] port 22.
debug1: Connection established.
debug1: permanently_set_uid: 0/0
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: identity file /root/.ssh/id_dsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa type -1
debug1: identity file /root/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.2_hpn13v11 FreeBSD-20130515
debug1: match: OpenSSH_6.2_hpn13v11 FreeBSD-20130515 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.8p2 FreeBSD-20110503
debug2: fd 4 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-rsa-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-dss-cert-v00@openssh.com,ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-sha1,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA 4e:a2:8c:18:ae:0b:db:58:c6:fc:82:de:d7:cd:ae:6d
debug1: Host '10.0.2.6' is known and matches the ECDSA host key.
debug1: Found key in /root/.ssh/known_hosts:1
debug1: ssh_ecdsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /root/.ssh/id_rsa (0x0)
debug2: key: /root/.ssh/id_dsa (0x0)
debug2: key: /root/.ssh/id_ecdsa (0x0)
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /root/.ssh/id_rsa
debug1: Trying private key: /root/.ssh/id_dsa
debug1: Trying private key: /root/.ssh/id_ecdsa
debug2: we did not send a packet, disable method
debug1: Next authentication method: password
crashplan@10.0.2.6's password:
debug2: we sent a password packet, wait for reply
Permission denied, please try again.
when i type inn the password for my crashplan user it seems that it wont accept my key
read around on google that ssh-copy-id will help but:
root@SYSTEM:/ # ssh-copy-id crashplan@10.0.2.6
ssh-copy-id: Command not found.
I need help to continue. ive tried many things but nothing works
fracai
The password won't be what you use to log in to your Crashplan account online, it'll be for the local user that Crashplan runs as. Can you get into the jail via jexec? Once there, you can change the crashplan user's password with 'passwd crashplan'.
Also, ssh-copy-id not being found on your local system just means you don't have that script. But you don't need to use it to get your key on the remote system. You can just append your public key to the end of the authorized_keys file in ~crashplan/.ssh/ in the crashplan jail.
Halfe
when creating a user in jail and is trying to ssh ports like i do. what IP do i have to use. do i have to use the jail IP or the NAS IPp
ssh -L 4200:127.0.0.1:4243 crashplan@192.168.1.103 -N -v -v
also. how can i show a list of users?
i want to delete a user that i dont want there. didnt find any on the google for showing and removing users in jail
fracai
The tunnel that you're creating is meant to connect your local machine where you're going to run the Crashplan GUI to the jail where the Crashplan service is running, so you want to run that command on your local machine and use the IP of the jail.
See this for getting a list of users and groups: http://serverfault.com/questions/240804/how-to-print-list-of-users-and-groups-on-freebsd
See here for removing a user: http://www5.us.freebsd.org/doc/handbook/users-modifying.html#users-rmuser
The jail is basically a regular FreeBSD environment, so don't bother searching for "jail remove user". Instead search for "FreeBSD remove user".
Finally, it seems like you're new to all this. If I'm not mistaken in that assumption, you should probably read up on some command line basics before you start doing too much. In general, be very careful and don't be afraid to ask questions. In fact, assume that the command that you think you know what it's going to do, is actually going to wipe all your data. ;-)
Halfe
Yes i'm a bit new but i have been able to install mysql and run it with xbmc. (easy)
what i want is now to setup backup to crashplan with a headless raspi. And so far my raspi is almost done.
and i'm reading a lot these days.
thanks for replying.
