New NAS Build for Home Use/Plex
wil421
I am planning to get a home NAS built. I have things like photos, GoPro Videos, and misc files. I plan to run Plex and I have made a CPU considerations and notes below. My current i7-7700k desktop/Plex Server can have trouble if it needs to transcode 4k to 1080p with one stream. I am picking up a Dell R720 locally for virtualization and to setup a home lab. The NAS may take some file backups and other things from the home lab. My personal data and Plex come first.
After looking at the hardware guide I have changed my original build to use ECC, Supermicro, Seasonic, and a few other things. I've also read a ton of threads. Especially the comments about old vs new hardware.
I understand the new vs old hardware argument but I would like to have longevity and lower power consumption. Upgrading RAM and replacing failed hard drives is ok. Upgrading and managing FreeNAS is also fine with me. I could also replace my cpu when the C246/LGA 1151 platform ages for datacenter use. My last few builds have lasted a long time.
Motherboard
Supermicro MBD-X11SCH-LN4F-O C246 LGA 1151 (X11SCH is preferred but I can't find it in the US.)
$270
CPU
Intel Xeon E-2146G (out of stock at most places, 2176G can be found.)
~$350 prices varies (2176G $375-$420)
RAM
2 x Supermicro 16GB SDRAM ECC Unbuffered DDR4 2666 MTA18ADF2G72AZ-2G6E1 (32GB Total)
2 x $110
Storage
6 x WD Red 2 TB NAS Drives (ZFS/RAIDZv2)
6 x $70
OS Drive
Existing Intel SSD or existing 2 x USB
Cooler
Existing cooler I have on hand is a Enermax ETS-N31.
Open to suggestions.
PSU
750w Seasonic FOCUS Plus Series SSR-750FX 80+ Gold ATX12V & EPS12V Full Modular
$110
Case
Rosewill RSV-L4000 - 4U Rackmount Server Chassis 8 Bays 7 Fans
$129
Server Rack will be purchased locally separate from the build.
Final Cost
~$1500
Questions
  1. What am I forgetting beside cables or maybe power cable extenders?
  2. Any concerns with TimeMachine and FreeNAS? I haven't searched much on this topic but I will.
Future Expansion
10G SFP+ Peer to Peer and/or 10G switched storage network separated from my home Unifi network. I have read and will confirm I am using FreeBSD supported NICs.
Plex Notes
I usually have only 1-2 1080p streams at a time sometimes 3 1080p. My current i7-7700k keeps up fine. Sometimes I have trouble with the 4k to 1080p transcode but not much lately after Plex app updates. If 2 people were to try a 4k to 1080p transcode then I will probably tell someone to watch something else.
Thank you,
wil421
Chris Moore
OS Drive
SSD is a better choice here.
4U Rackmount Server
with this and
Final Cost
~$1500
If you are going to spend that much and you are looking to get a 4U rack mount server, you should get a used server from eBay instead.
Something like this would be good:
https://www.ebay.com/itm/Supermicro-4U-SAS2-Storage-2x-E5-2620-16GB-LSI-9265-8I-Rails/383001589533
Just change out the hardware RAID controller to a SAS HBA like this:
https://www.ebay.com/itm/HP-H220-6G...0-IT-Mode-for-ZFS-FreeNAS-unRAID/162862201664
and start plugging in your drives.
If I recall correctly, that server can be upgraded to 1TB of RAM using Registered ECC memory and you can upgrade the processors if you need more horsepower. It is a real workhorse.
wil421
with this and
The hardware is tempting but the 4k transcode ability could be lacking. I will have to upgrade sooner.
4U is not a requirement. 8 drives would be preferred. I do not know much about server chassis.
Chris Moore
Chris Moore
Are these servers loud?
It depends on details of the specific unit you are looking at and your tolerance. The one I have is not loud by my standard. I have two servers in my office at home and I am able to have a conversation without difficulty. Here is a link to a YouTube video I made while I was in my office with the server running:
https://www.youtube.com/watch?v=cPv_ikws7A0
