First Build CPU check
paul_sam
Hi! This is my first build and would like some feedback.
I’ll use Plex, zoneminder, homeassistant, etc (nextcloud, opensense, pihole, adgaurd).
Plex will have a max transcoding of 1 - 4k and 1 - 1080p video simultaneously.
Zoneminder will have max 4 1080p cams @ 2 -12 fps
Will an AMD Ryzen 5 5600g(70usd) be enough or should I go for an AMD Ryzen 7 5800x(105usd)?
Will 16 GB RAM be enough or should I go for 32GB?
Mobo - ASRock A520M-HDV
sdaqo
The 7 5800x does not have integrated graphics, so no video encoding which you will probably want for Plex transcoding. The other one should be fine.
sdaqo
Another thing... I don't know if Plex supports amd hw transcoding on Linux, it works on windows apparently. You could opt for jellyfin which does support amd hw transcoding on Linux.
paul_sam
Jelly is fine too.
Can't you do CPU transcoding? I meant that. Isn't it better than iGPU transcoding?
sdaqo
You can use the CPU to transcode, the thing is it is slow and clogs up the CPU usage. If you can you should offload to a external GPU or in your case a igpu, this will be much faster and you can still use your CPU normally.
NugentS
I don't believe that Plex supports transcoding on an AMD iGPU
sdaqo
Oops didn't mean to send that comment alone. Anyways on that site it says that AMD is supported but not properly tested.
paul_sam
I know about that, but that's Hardware acceleration for GPUs, I meant Software transcoding(H.264 I think? the default one).
Plex has CPU guidelines based on the PassMark score for Software transcoding. [here]
4K HDR (50Mbps, 10-bit HEVC) file: 17000 PassMark score (being transcoded to 10Mbps 1080p)
4K SDR (40Mbps, 8-bit HEVC) file: 12000 PassMark score (being transcoded to 10Mbps 1080p)
1080p (10Mbps, H.264) file: 2000 PassMark score
720p (4Mbps, H.264) file: 1500 PassMark score
So I thought there wouldn't be problems with Software transcoding in AMD.
And the Ryzen 5 5600g has a score of 19928.
So this should work, right? Or is my theory wrong?
NugentS
No - your theory is right
NugentS
It depends on what you want the VM's & apps to do.
You probably want considerably more memory than 16GB.
Getmodnow - a place to immerse yourself in the unlimited world of gaming and technology applications for the Android operating system! Getmodnow is not just a download place, but an active community where you can discover and experience thousands of unique apps and games for free. Bringing users a diverse collection, from top applications to attractive mod versions, all completely free. With Getmodnow, you can quickly access and download the hottest game apps, from puzzles to action, with unlimited creativity and entertainment.
For your setup, the AMD Ryzen 5 5600g will handle your tasks well, but if your budget allows, the Ryzen 7 5800x will provide more power. 16GB RAM should be enough, but if you plan to run multiple apps at the same time, 32GB can provide some headroom. :grin:
