New LetsEncrypt Cert not being issued to clients
derWalter
even though I have a valid cert, if I try to access any.mydomain.at (which is pointed to my public nas ip via cloudflare dns), I get an connection error.
Web sites prove their identity via certificates, which are valid for a set time period. The certificate for any.mydomain.at expired on 17/07/2023.
Error code: SEC_ERROR_EXPIRED_CERTIFICATE
tried to flush dns caches on clients and reboot the nas (as this helped in the past with LetsEncrypt Cert issues...) but to no avail.
I am using traefik and nexcloud, both from the truecharts repo and they are not up to date (as there are breaking upgrades, again,
where I dont find the time to do atm...) but everyting was working till I rebooted to make the new LE cert working.
Any clues, tipps, ideas, help is highly appreacheated.
This sounds like it's inviting a visit from @RussianMafia, but...
What's the relationship among Traefik, the TrueNAS GUI, and the Let's Encrypt cert you mention? Is the GUI behind Traefik, as TrueCharts' own docs suggest? Or is it exposed directly?
If the GUI is behind Traefik, are you using cluster-issuer to get the cert? Or are you telling Traefik to use the cert from TrueNAS? The latter is no longer supported, as I understand.
Not sure where you're up to with your apps exactly, but some of those breaking changes introduced different ways to handle certificates, "forcing" us all towards cluster-issuer.
Look again in your settings and see if you need to supply your certificate information again in the app config.
derWalter
yes, its behind traefik.
Dang it ..... so this should look completely different now I guess?
can some one drop me a link where I can start reading, or some buzzwords too google my self to knowledge?
thanks for the tipps so far!
