Hi All,
I have some questions after proper raid setup and how it works with a pool.
The system I will run on a SuperMicro sink with 16 hotswap disks and 3x internal.
The use will be to keep the virtual machines via NFS, and some data.
my setup:
dual xeon cpu
24GB RAM
8x1TB Seagate SAS - (later + 8x1tb) total 16tb
2x20G SSD ZIL
1x 120G SSD Cache
My question is how to set up the raid.
My problem is that I can just remove the eight disks for migration before I can release the other eight disks.
How do I set up the raid for those first eight disks and then to add the Additional 8 drives to and penetrate the data that is on them first 8 disks for all 16 to get a more balanced load and better performance.
Is this possible and what zraid level should I choose?
8xraidz2 without hotspare and then later when I have figjort the other eight disks to add the other in the pool? and will the data be disseminated automatically melancholy them two raidz2? or is there a command you can run?
Tips and thoughts please.
/ John
my setup:
dual xeon cpu
24GB RAM
2x20G SSD ZIL
1x 120G SSD Cache
/ John
