New Drive Resilvering Multiple Times (Write no Reads)
evlvd
One of my drives started giving me errors and doing small resilvers (a few KB to a few MB) so I replaced it with a new 3tb WD Red drive (ada1). The resilver completed, then the next day I noticed it was resilvering again. Strange.
I was going to replace another drive that had an increased error count, but was waiting for the resilvering to finish, but it never finishes, it just keeps going. I noticed the RED drive ada1 has just been writing, and not reading.
I'm not sure if there is something wrong with the new RED drive as I haven't seen this before.
I'm running 2 raidz1 arrays (media only) and have another RED drive arriving tomorrow, but I don't know at what point I should change the drive out.
m0nkey_
Have you performed a SMART test on the drives? Could you run 'smartctl' on the degraded drives. I'd also be looking to backup your data as soon as possible, just in case your pool does decide to disappear on you.
Robert Trevellyan
Pony Wrangler
+1
With RAIDZ1 vdevs and >1TB drives, your entire pool is in a precarious state.
Strange indeed, and maybe indicative of a different hardware problem.
Please take a look at the forum rules and post the relevant info to give folks a better chance of helping you.
evlvd
Thanks for the quick response. Data is backed up, looking to switch to raidz2 or 3 soon once I can migrate data.
Signature updated to show system.
Freenas is showing my pool is healthy, but still resilvering, it also looks like the drive I'm trying to replace is spitting back lots of errors.
Here are the smartctl's for both drives, RED first, then Seagate 3tb.
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N1YE760S
LU WWN Device Id: 5 0014ee 261673553
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Oct 28 09:09:14 2015 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (41520) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 417) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       366
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       39
194 Temperature_Celsius     0x0022   119   111   000    Old_age   Always       -       31
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST3000DM001-9YN166
Serial Number:    W1F0QFJR
LU WWN Device Id: 5 000c50 0529ac31b
Firmware Version: CC4B
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
Local Time is:    Wed Oct 28 09:08:53 2015 PDT
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    been run.
data collection:         (  575) seconds.
                    command.
                    power-saving mode.
recommended polling time:      (   1) minutes.
recommended polling time:      ( 332) minutes.
SCT capabilities:            (0x3085)    SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   117   097   006    Pre-fail  Always       -       153647096
  3 Spin_Up_Time            0x0003   097   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       210
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   050   050   030    Pre-fail  Always       -       12210893547295
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       10381
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       56
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   001   001   000    Old_age   Always       -       516
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       2 2 6
189 High_Fly_Writes         0x003a   098   098   000    Old_age   Always       -       2
190 Airflow_Temperature_Cel 0x0022   062   053   045    Old_age   Always       -       38 (Min/Max 24/44)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       35
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       270
194 Temperature_Celsius     0x0022   038   047   000    Old_age   Always       -       38 (0 18 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       16
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       16
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       3
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       10064h+58m+51.392s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       121203013777523
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       167662569814704
ATA Error Count: 514 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Error 514 occurred at disk power-on lifetime: 10380 hours (432 days + 12 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 40 ff ff ff 4f 00  12d+12:13:27.723  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  12d+12:13:27.584  READ LOG EXT
  60 00 40 ff ff ff 4f 00  12d+12:13:24.761  READ FPDMA QUEUED
Error 513 occurred at disk power-on lifetime: 10380 hours (432 days + 12 hours)
  60 00 08 ff ff ff 4f 00  12d+12:13:24.760  READ FPDMA QUEUED
  60 00 40 ff ff ff 4f 00  12d+12:13:24.760  READ FPDMA QUEUED
Error 512 occurred at disk power-on lifetime: 10380 hours (432 days + 12 hours)
  60 00 40 ff ff ff 4f 00  12d+12:13:21.876  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00  12d+12:13:21.876  READ FPDMA QUEUED
  60 00 40 ff ff ff 4f 00  12d+12:13:21.875  READ FPDMA QUEUED
Error 511 occurred at disk power-on lifetime: 10380 hours (432 days + 12 hours)
  60 00 08 ff ff ff 4f 00  12d+12:13:18.855  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00  12d+12:13:18.854  READ FPDMA QUEUED
  60 00 40 ff ff ff 4f 00  12d+12:13:18.842  READ FPDMA QUEUED
Error 510 occurred at disk power-on lifetime: 10380 hours (432 days + 12 hours)
  40 51 00 ff ff ff 0f  Error: WP at LBA = 0x0fffffff = 268435455
  61 00 40 ff ff ff 4f 00  12d+12:13:15.844  WRITE FPDMA QUEUED
  60 00 40 ff ff ff 4f 00  12d+12:13:15.838  READ FPDMA QUEUED
  61 00 40 ff ff ff 4f 00  12d+12:13:15.838  WRITE FPDMA QUEUED
  61 00 10 ff ff ff 4f 00  12d+12:13:15.807  WRITE FPDMA QUEUED
# 1  Short offline       Completed without error       00%      8357         -
# 2  Short offline       Completed without error       00%      8308         -
# 3  Short offline       Completed without error       00%      8260         -
# 4  Short offline       Completed without error       00%      8212         -
# 5  Extended offline    Completed without error       00%      8195         -
# 6  Short offline       Completed without error       00%      8164         -
# 7  Short offline       Completed without error       00%      8116         -
# 8  Short offline       Completed without error       00%      8068         -
# 9  Short offline       Completed without error       00%      8020         -
#10  Short offline       Completed without error       00%      7972         -
#11  Short offline       Completed without error       00%      7924         -
#12  Short offline       Completed without error       00%      7876         -
#13  Extended offline    Completed without error       00%      7861         -
#14  Short offline       Completed without error       00%      7828         -
#15  Short offline       Completed without error       00%      7780         -
#16  Short offline       Completed without error       00%      7732         -
#17  Short offline       Completed without error       00%      7684         -
#18  Short offline       Completed without error       00%      7636         -
#19  Short offline       Completed without error       00%      7588         -
#20  Short offline       Completed without error       00%      7540         -
#21  Short offline       Completed without error       00%      7504         -
And here is a screenshot of the zpool status again showing the resilvering is still going, making no real progress.
jgreco
Resident Grinch
Two drives are resilvering but you only have RAIDZ1? ... (*little puzzled*)
Is the scan progress showing any progress being made? i.e. run it every few minutes and look for changes in the amount completed.
Robert Trevellyan
Pony Wrangler
The WD Red looks OK but the Seagate looks a bit sick. Unfortunately the ST3000DM001 has a history of early failure. This thread came up when I Googled "RAIDZ1 two drives resilvering" and it's the exact same revision (9YN166).
I too am puzzled by your zpool status. I'm starting to wonder if there's an edge case bug involved.
If a disk is failing, as seems likely, resilvering could take a very long time, and may never actually complete.
Might make sense to start on this project now rather than sinking more time into the current problem.
evlvd
I figured they were probably resilvering different pieces of data blocks, and could continue on grabbing data from each other in different places. Plus, the RED drive should be complete, so I don't know why it is resilvering.
It does progress fairly quickly (as quickly as my occasional resilvers took before I replaced a drive) but I never see it finish.
I don't know if it is related, but I can't open the plugins -> installed page on the webgui, and one of my plugins doesn't load my settings each time.
All my other data is intact and runs fine, performance is maxed out over cifs. The only lost file is an old history revision from October 1st.
I'd love to, but need to figure out what setup raidz2 or raidz3 I'd like, and need drives to migrate data to. Even though data is backed up, it's offsite and I'd like to move everything at once.
I was hoping I could just swap out this failing drive for my new RED drive, then swap out the rest next. Now I don't know if I can replace the drive while it is still resilvering.
jgreco
Resident Grinch
It just slows down when it doesn't finish? If so, the pool might be damaged. If so, back up the pool and start over.
Robert Trevellyan
Pony Wrangler
Intriguing hypothesis.
Seems like asking for trouble to me.
evlvd
It never slows down. Each morning I check it and it is still resilvering, but it always says resilvering since 10/28 (or that morning). So perhaps it is finishing, but then starts again quickly after.
It never freezes, and the progress time always decreases, but is usually around 10-14 hours when I check it.
What I'm mostly concerned about is this new RED drive only writing data, and not reading anything while it is resilvering, as if none of the data written is taking and it just keeps starting over.
Here is the zpool status taken just now, showing the progress and speed:
[root@freenas] ~# zpool status
  pool: Media
state: ONLINE
status: One or more devices is currently being resilvered.  The pool will
        continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Wed Oct 28 15:22:49 2015
        2.28T scanned out of 16.5T at 268M/s, 15h26m to go
        467G resilvered, 13.85% done
        Media                                           ONLINE       0     0     8
          raidz1-0                                      ONLINE       0     0    16
            gptid/b2487721-696e-11e4-8228-0cc47a40699d  ONLINE       0     0     0
            gptid/3de3a420-712a-11e5-9363-0cc47a40699d  ONLINE       0     0     0  (resilvering)
            gptid/b36c7fb6-696e-11e4-8228-0cc47a40699d  ONLINE       0     0     0
            gptid/b4636191-696e-11e4-8228-0cc47a40699d  ONLINE       8     0     0  (resilvering)
            gptid/b5485367-696e-11e4-8228-0cc47a40699d  ONLINE       0     0     0
          raidz1-1                                      ONLINE       0     0     0
            gptid/146e9344-080f-11e5-b77a-0cc47a40699d  ONLINE       0     0     0
            gptid/14d76f68-080f-11e5-b77a-0cc47a40699d  ONLINE       0     0     0
            gptid/152f5a34-080f-11e5-b77a-0cc47a40699d  ONLINE       0     0     0
            gptid/158bd979-080f-11e5-b77a-0cc47a40699d  ONLINE       0     0     0
            gptid/15f20b06-080f-11e5-b77a-0cc47a40699d  ONLINE       0     0     0
jgreco
Resident Grinch
I think your pool's busted, but I haven't seen enough failures of this sort to know for sure. I definitely strongly emphatically suggest migrating the data elsewhere immediately or even sooner.
evlvd
Will buy some drives tonight so I can rearrange.
Thanks everyone for the input. I'm still not sure what to think about the new RED drive that isn't reading.
jgreco
Resident Grinch
We're thinking that it's reading just fine but that the pool's corrupt or something like that.
  pool: Media
state: ONLINE
        Media                                           ONLINE       0     0     8 <---- Very bad
          raidz1-0                                      ONLINE       0     0    16 <---- Very bad
See the "Very bad" I listed above. Your zpool *is* damaged. You need to destroy and recreate it from backups.
