Network speeds issues to OpenVpn in iocage jail.
deanhuff
I'm seeing differing network speeds depending on where I place file transfers to and from my office network from my home. The office network is running FreeNAS with OpenVpn in an iocage jail. Additionally my Workstation1 at the office is in DMZ so I can ssh directly to it from home.
The topology:
Freenas - is running at my office 10.217.50.10
OpenVPN - is running in an iocage jail on the Freenas 10.217.50.13
Workstation1 - A workstation at the office on the same network segment is 10.217.50.169. (In DMZ, can be ssh'd to directly)
My house has 500Mb internet
My office has 1000Mb internet
A scp for a ~800MB iso file consistently shows results like these:
House to Workstation 1 vi scp to public IP (DMZ address bypass everything freenas) - 36MB/s
House to Workstation1 via scp through VPN - 17.2MB/s
House to OpenVPN jail via scp through VPN - 17.4/s
House to FreeNas via scp through VPN - 1.6MB/s
So observations. VPN speeds are roughly half that of direct connection. VPN to the NAS is way slower at just 1.6MB/s.
Does anyone know why my connection from OpenVPN to Freenas is so slow through the VPN? When I scp files directly from the OpenVPN jail to the Freenas on which its hosted I'm getting speeds of ~120MB/sec.
Here's ifconfig from the OpenVPN Jail
$ ifconfig -a
    options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8<VLAN_MTU>
    ether 02:ff:60:36:38:32
    hwaddr 02:2e:d0:00:07:0b
    inet 10.217.50.13 netmask 0xffffff00 broadcast 10.217.50.255
    nd6 options=1<PERFORMNUD>
    status: active
    groups: epair
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1500
    options=80000<LINKSTATE>
    inet 10.8.0.1 --> 10.8.0.2 netmask 0xffffff00
    groups: tun
    Opened by PID 6051
And the ifconfig from the FreeNAS
root@freenas:~ # ifconfig -a
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
    ether 0c:c4:7a:12:52:5e
    hwaddr 0c:c4:7a:12:52:5e
    inet 10.217.50.10 netmask 0xff000000 broadcast 10.255.255.255
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
    ether 0c:c4:7a:12:52:5f
    hwaddr 0c:c4:7a:12:52:5f
    status: no carrier
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
    groups: lo
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: Attached to VTG_SYSIMG
    ether 00:bd:7d:57:f9:00
    hwaddr 00:bd:7d:57:f9:00
    status: active
    groups: tap
    Opened by PID 5564
    ether 02:c8:7c:65:26:00
    groups: bridge
    member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 6 priority 128 path cost 2000
    member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 1 priority 128 path cost 20000
    member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 4 priority 128 path cost 2000000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: openvpn as nic: epair0b
    options=8<VLAN_MTU>
    ether 02:ff:60:36:38:31
    hwaddr 02:2e:d0:00:06:0a
    inet6 fe80::ff:60ff:fe36:3831%vnet0:1 prefixlen 64 scopeid 0x6
    nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
    status: active
    groups: epair
And here's my iocage config.json file:
root@freenas:/mnt/zvol1/iocage/jails/openvpn # more config.json
    "CONFIG_VERSION": "14.1",
    "allow_chflags": "0",
    "allow_mlock": "0",
    "allow_mount": "0",
    "allow_mount_devfs": "0",
    "allow_mount_nullfs": "0",
    "allow_mount_procfs": "0",
    "allow_mount_tmpfs": "0",
    "allow_mount_zfs": "0",
    "allow_quotas": "0",
    "allow_raw_sockets": "1",
    "allow_set_hostname": "1",
    "allow_socket_af": "0",
    "allow_sysvipc": "0",
    "allow_tun": "1",
    "available": "readonly",
    "basejail": "no",
    "boot": "on",
    "bpf": "no",
    "children_max": "0",
    "cloned_release": "11.2-RELEASE-p8",
    "comment": "none",
    "compression": "lz4",
    "compressratio": "readonly",
    "coredumpsize": "off",
    "count": "1",
    "cpuset": "off",
    "cputime": "off",
    "datasize": "off",
    "dedup": "off",
    "defaultrouter": "10.217.50.1",
    "defaultrouter6": "none",
    "depends": "none",
    "devfs_ruleset": "4",
    "dhcp": "off",
    "enforce_statfs": "2",
    "exec_clean": "1",
    "exec_fib": "0",
    "exec_jail_user": "root",
    "exec_poststart": "/usr/bin/true",
    "exec_poststop": "/usr/bin/true",
    "exec_prestart": "/usr/bin/true",
    "exec_prestop": "/usr/bin/true",
    "exec_start": "/bin/sh /etc/rc",
    "exec_stop": "/bin/sh /etc/rc.shutdown",
    "exec_system_jail_user": "0",
    "exec_system_user": "root",
    "exec_timeout": "60",
    "host_domainname": "vtg",
    "host_hostname": "openvpn",
    "host_hostuuid": "openvpn",
    "host_time": "yes",
    "hostid": "30E3513E-5BC0-11E4-899B-09DC14AEE001",
    "hostid_strict_check": "off",
    "interfaces": "vnet0:bridge0",
    "ip4": "new",
    "ip4_addr": "vnet0|10.217.50.13/24",
    "ip4_saddrsel": "1",
    "ip6": "new",
    "ip6_addr": "vnet0|accept_rtadv",
    "ip6_saddrsel": "1",
    "jail_zfs": "off",
    "jail_zfs_dataset": "iocage/jails/openvpn/data",
    "jail_zfs_mountpoint": "none",
    "last_started": "2020-05-08 01:39:29",
    "login_flags": "-f root",
    "mac_prefix": "02ff60",
    "maxproc": "off",
    "memorylocked": "off",
    "memoryuse": "off",
    "mount_devfs": "1",
    "mount_fdescfs": "1",
    "mount_linprocfs": "0",
    "mount_procfs": "0",
    "mountpoint": "readonly",
    "msgqqueued": "off",
    "msgqsize": "off",
    "nmsgq": "off",
    "notes": "none",
    "nsemop": "off",
    "nshm": "off",
    "nthr": "off",
    "openfiles": "off",
    "origin": "readonly",
    "owner": "root",
    "pcpu": "off",
    "priority": "99",
    "pseudoterminals": "off",
    "quota": "none",
    "release": "11.2-RELEASE-p8",
    "reservation": "none",
    "resolver": "/etc/resolv.conf",
    "rlimits": "off",
    "securelevel": "2",
    "shmsize": "off",
    "stacksize": "off",
    "stop_timeout": "30",
    "swapuse": "off",
    "sync_state": "none",
    "sync_target": "none",
    "sync_tgt_zpool": "none",
    "sysvmsg": "new",
    "sysvsem": "new",
    "sysvshm": "new",
    "template": "no",
    "type": "jail",
    "used": "readonly",
    "vmemoryuse": "off",
    "vnet": "on",
    "vnet0_mac": "02ff60363831 02ff60363832",
    "vnet1_mac": "none",
    "vnet2_mac": "none",
    "vnet3_mac": "none",
    "vnet_default_interface": "auto",
    "vnet_interfaces": "none",
    "wallclock": "off"
and finally, my Freenas release info:
root@freenas:/mnt/zvol1/iocage/jails/openvpn #  cat /etc/motd
FreeBSD 11.2-STABLE (FreeNAS.amd64) #0 r325575+4710c8b6420(HEAD): Fri Feb 14 13:59:19 UTC 2020
    FreeNAS (c) 2009-2019, The FreeNAS Development Team
    All rights reserved.
    FreeNAS is released under the modified BSD license.
    For more information, documentation, help or support, go here:
    http://freenas.org
Welcome to FreeNAS
