flashdrive
- Apr 2, 2021
tldr:
solution / proper howto:
www.truenas.com
I want to remove a LAN switch out of the setup.
Situation:
TrueNAS host:
1 onboard NIC with 1x LAN port
1 PCIe NIC with 2x LAN port -> connected to Switch 1 and Switch 2
client PC:
1 PCIe NIC with 2x LAN port -> connected to Switch 2
goal:
Only TrueNAS host will connect to 1 Switch with WAN connection.
client PC will connect to TrueNAS host and use the WAN connection from there.
How would I set this up in TrueNAS?
docs.freebsd.org
SOLVED - Network - replace switch with internal NIC & routing - howto?
tldr: solution / proper howto: https://www.truenas.com/community/threads/network-replace-switch-with-internal-nic-routing-howto.96040/post-664230 Hello, I want to remove a LAN switch out of the setup. Situation: TrueNAS host: 1 onboard NIC with 1x LAN port 1 PCIe NIC with 2x LAN port ->...
Situation:
TrueNAS host:
client PC:
goal:
Chapter 34. Advanced Networking
Advanced networking in FreeBSD: basics of gateways and routes, CARP, how to configure multiple VLANs on FreeBSD, etc
