 - Nov 25, 2013
Hi all,
my network setup with 20.10 was
Protocol LACP (Cisco IOS on the other side), IPv4 and IPv6 on the vlan100 interface. Worked great.
After upgrade to 20.12 via UI the network configuration was "gone". OK, the system wasn't productive, anyway, so I reinstalled from a 20.12 ISO. Network configuration for eno1 is working. The problem is that the 3 other interfaces are nowhere to be found so I cannot create the bond0 ...
Any hints appreciated. Thanks!
vlan100 ---> bond0 --+--> eno1
                     \--> eno2Protocol LACP (Cisco IOS on the other side), IPv4 and IPv6 on the vlan100 interface. Worked great.
ifconfig -a
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.93.203  netmask 255.255.255.0  broadcast 192.168.93.255
        inet6 2003:a:d59:3800:3eec:efff:fe00:5430  prefixlen 64  scopeid 0x0<global>
        ether 3c:ec:ef:00:54:30  txqueuelen 1000  (Ethernet)
        RX packets 9672  bytes 1344507 (1.2 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 7620  bytes 9634884 (9.1 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 1576  bytes 412549 (402.8 KiB)
        TX packets 1576  bytes 412549 (402.8 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0Code:
dmesg|grep eno [ 1.709159] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio) [ 8.623130] ixgbe 0000:06:00.0 eno1: renamed from eth0 [ 38.462082] ixgbe 0000:06:00.0: registered PHC device on eno1 [ 42.323274] ixgbe 0000:06:00.0 eno1: NIC Link is Up 1 Gbps, Flow Control: None [ 42.349583] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
dmesg|grep ixgbe [ 6.185901] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver [ 6.197371] ixgbe: Copyright (c) 1999-2016 Intel Corporation. [ 6.589557] ixgbe 0000:06:00.0: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0 [ 6.725153] ixgbe 0000:06:00.0: MAC: 6, PHY: 27, PBA No: 030000-000 [ 6.736527] ixgbe 0000:06:00.0: 3c:ec:ef:00:54:30 [ 6.797153] ixgbe 0000:06:00.0: Intel(R) 10 Gigabit Network Connection [ 6.814726] libphy: ixgbe-mdio: probed [ 7.171212] ixgbe 0000:06:00.1: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0 [ 7.319179] ixgbe 0000:06:00.1: MAC: 6, PHY: 27, PBA No: 030000-000 [ 7.331482] ixgbe 0000:06:00.1: 3c:ec:ef:00:54:31 [ 7.386119] ixgbe 0000:06:00.1: Intel(R) 10 Gigabit Network Connection [ 7.775332] ixgbe 0000:07:00.0: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0 [ 7.923189] ixgbe 0000:07:00.0: MAC: 6, PHY: 27, PBA No: 030000-000 [ 7.935513] ixgbe 0000:07:00.0: 3c:ec:ef:00:54:32 [ 7.988217] ixgbe 0000:07:00.0: Intel(R) 10 Gigabit Network Connection [ 8.369736] ixgbe 0000:07:00.1: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0 [ 8.519177] ixgbe 0000:07:00.1: MAC: 6, PHY: 27, PBA No: 030000-000 [ 8.532514] ixgbe 0000:07:00.1: 3c:ec:ef:00:54:33 [ 8.587178] ixgbe 0000:07:00.1: Intel(R) 10 Gigabit Network Connection [ 8.623130] ixgbe 0000:06:00.0 eno1: renamed from eth0 [ 38.462082] ixgbe 0000:06:00.0: registered PHC device on eno1 [ 42.323274] ixgbe 0000:06:00.0 eno1: NIC Link is Up 1 Gbps, Flow Control: None
