Stefan Konstantinovitsch
- Nov 17, 2016
Hi :)
I have an issue with the network performance on my FreeNAS 9.10 server. I'm running a 1Gb setup, but the performance is more like a 100Mb setup.
I started troubleshooting, when I noticed that Transmission wouldn't download faster than 10MB/s with peaks at 14MB/s (my internet connection is 300Mb/300Mb) and I intially thought it was a limitation within Transmission, but after troubleshooting that, I tried a 4Gig file transfer from a Win10 PC and the speed caps at 11,4MB/s.
I have a 4x1Gb Intel NIC running with LACP, but have also enabled an onboard 1Gig Intel NIC for troubleshooting purposes, but I have the same performance through both NICs.
The server is connected to a D-Link DGS-3224TGR and a Cisco small business RV220W router.
Output from ifconfig:
Output from pciconf -lv
I have been researching for days now, without finding a solution, so I really hope you guys can help.
BTW - I'm convinced that the performance was fine in FreeNAS 9.3 where I could get file transfer speeds of 85-110 MB/s.
[root@storage] ~# ifconfig ix0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 90:e2:ba:84:66:fc nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier ix1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 90:e2:ba:84:66:fd nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO> ether 00:1b:fc:b3:93:a8 inet 192.168.0.110 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active em1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO> ether 00:1b:fc:b3:93:a9 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether 00:1b:21:74:94:48 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether 00:1b:21:74:94:48 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether 00:1b:21:74:94:48 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb3: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether 00:1b:21:74:94:48 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether 00:1b:21:74:94:48 inet 192.168.0.4 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active laggproto lacp lagghash l2,l3,l4 laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: igb1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: igb2 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: igb3 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:c5:fd:8e:f0:00 nd6 options=9<PERFORMNUD,IFDISABLED> id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 13 priority 128 path cost 2000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 12 priority 128 path cost 2000 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 3 priority 128 path cost 20000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0c:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0d:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
[root@storage] ~# pciconf -lv hostb0@pci0:0:0:0: class=0x060000 card=0x82161043 chip=0x25d48086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000V Chipset Memory Controller Hub' class = bridge subclass = HOST-PCI pcib1@pci0:0:2:0: class=0x060400 card=0x00000000 chip=0x25f78086 rev=0xb1 hdr=0x01 vendor = 'Intel Corporation' device = '5000 Series Chipset PCI Express x8 Port 2-3' class = bridge subclass = PCI-PCI pcib6@pci0:0:3:0: class=0x060400 card=0x00000000 chip=0x25e38086 rev=0xb1 hdr=0x01 vendor = 'Intel Corporation' device = '5000 Series Chipset PCI Express x4 Port 3' class = bridge subclass = PCI-PCI none0@pci0:0:8:0: class=0x088000 card=0x82161043 chip=0x1a388086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset DMA Engine' class = base peripheral hostb1@pci0:0:16:0: class=0x060000 card=0x82161043 chip=0x25f08086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset FSB Registers' class = bridge subclass = HOST-PCI hostb2@pci0:0:16:1: class=0x060000 card=0x82161043 chip=0x25f08086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset FSB Registers' class = bridge subclass = HOST-PCI hostb3@pci0:0:16:2: class=0x060000 card=0x82161043 chip=0x25f08086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset FSB Registers' class = bridge subclass = HOST-PCI hostb4@pci0:0:17:0: class=0x060000 card=0x82161043 chip=0x25f18086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset Reserved Registers' class = bridge subclass = HOST-PCI hostb5@pci0:0:19:0: class=0x060000 card=0x82161043 chip=0x25f38086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset Reserved Registers' class = bridge subclass = HOST-PCI hostb6@pci0:0:21:0: class=0x060000 card=0x82161043 chip=0x25f58086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset FBD Registers' class = bridge subclass = HOST-PCI hostb7@pci0:0:22:0: class=0x060000 card=0x82161043 chip=0x25f68086 rev=0xb1 hdr=0x00 vendor = 'Intel Corporation' device = '5000 Series Chipset FBD Registers' class = bridge subclass = HOST-PCI pcib7@pci0:0:28:0: class=0x060400 card=0x81dc1043 chip=0x26908086 rev=0x09 hdr=0x01 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset PCI Express Root Port 1' class = bridge subclass = PCI-PCI uhci0@pci0:0:29:0: class=0x0c0300 card=0x81dc1043 chip=0x26888086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset UHCI USB Controller' class = serial bus subclass = USB uhci1@pci0:0:29:1: class=0x0c0300 card=0x81dc1043 chip=0x26898086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset UHCI USB Controller' class = serial bus subclass = USB uhci2@pci0:0:29:2: class=0x0c0300 card=0x81dc1043 chip=0x268a8086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset UHCI USB Controller' class = serial bus subclass = USB uhci3@pci0:0:29:3: class=0x0c0300 card=0x81dc1043 chip=0x268b8086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset UHCI USB Controller' class = serial bus subclass = USB ehci0@pci0:0:29:7: class=0x0c0320 card=0x81dc1043 chip=0x268c8086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset EHCI USB2 Controller' class = serial bus subclass = USB pcib11@pci0:0:30:0: class=0x060401 card=0x81dc1043 chip=0x244e8086 rev=0xd9 hdr=0x01 vendor = 'Intel Corporation' device = '82801 PCI Bridge' class = bridge subclass = PCI-PCI isab0@pci0:0:31:0: class=0x060100 card=0x81dc1043 chip=0x26708086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset LPC Interface Controller' class = bridge subclass = PCI-ISA atapci0@pci0:0:31:1: class=0x01018a card=0x81dc1043 chip=0x269e8086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB IDE Controller' class = mass storage subclass = ATA atapci1@pci0:0:31:2: class=0x01018f card=0x81dc1043 chip=0x26808086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset SATA IDE Controller' class = mass storage subclass = ATA none1@pci0:0:31:3: class=0x0c0500 card=0x81dc1043 chip=0x269b8086 rev=0x09 hdr=0x00 vendor = 'Intel Corporation' device = '631xESB/632xESB/3100 Chipset SMBus Controller' class = serial bus subclass = SMBus pcib2@pci0:1:0:0: class=0x060400 card=0x82161043 chip=0x35008086 rev=0x01 hdr=0x01 vendor = 'Intel Corporation' device = '6311ESB/6321ESB PCI Express Upstream Port' class = bridge subclass = PCI-PCI pcib5@pci0:1:0:3: class=0x060400 card=0x82161043 chip=0x350c8086 rev=0x01 hdr=0x01 vendor = 'Intel Corporation' device = '6311ESB/6321ESB PCI Express to PCI-X Bridge' class = bridge subclass = PCI-PCI pcib3@pci0:2:0:0: class=0x060400 card=0x82161043 chip=0x35108086 rev=0x01 hdr=0x01 vendor = 'Intel Corporation' device = '6311ESB/6321ESB PCI Express Downstream Port E1' class = bridge subclass = PCI-PCI pcib4@pci0:2:2:0: class=0x060400 card=0x82161043 chip=0x35188086 rev=0x01 hdr=0x01 vendor = 'Intel Corporation' device = '6311ESB/6321ESB PCI Express Downstream Port E3' class = bridge subclass = PCI-PCI ix0@pci0:3:0:0: class=0x020000 card=0x000c8086 chip=0x10fb8086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82599ES 10-Gigabit SFI/SFP+ Network Connection' class = network subclass = ethernet ix1@pci0:3:0:1: class=0x020000 card=0x000c8086 chip=0x10fb8086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82599ES 10-Gigabit SFI/SFP+ Network Connection' class = network subclass = ethernet em0@pci0:4:0:0: class=0x020000 card=0x82171043 chip=0x10968086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '80003ES2LAN Gigabit Ethernet Controller (Copper)' class = network subclass = ethernet em1@pci0:4:0:1: class=0x020000 card=0x82171043 chip=0x10968086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '80003ES2LAN Gigabit Ethernet Controller (Copper)' class = network subclass = ethernet aac0@pci0:5:1:0: class=0x010400 card=0x029b9005 chip=0x02869005 rev=0x02 hdr=0x00 vendor = 'Adaptec' device = 'AAC-RAID (Rocket)' class = mass storage subclass = RAID pcib8@pci0:7:0:0: class=0x060400 card=0x00000000 chip=0x8018111d rev=0x0e hdr=0x01 vendor = 'Integrated Device Technology, Inc. [IDT]' device = 'PES12N3A PCI Express Switch' class = bridge subclass = PCI-PCI pcib9@pci0:8:2:0: class=0x060400 card=0x00000000 chip=0x8018111d rev=0x0e hdr=0x01 vendor = 'Integrated Device Technology, Inc. [IDT]' device = 'PES12N3A PCI Express Switch' class = bridge subclass = PCI-PCI pcib10@pci0:8:4:0: class=0x060400 card=0x00000000 chip=0x8018111d rev=0x0e hdr=0x01 vendor = 'Integrated Device Technology, Inc. [IDT]' device = 'PES12N3A PCI Express Switch' class = bridge subclass = PCI-PCI igb0@pci0:9:0:0: class=0x020000 card=0xa02c8086 chip=0x10e88086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82576 Gigabit Network Connection' class = network subclass = ethernet igb1@pci0:9:0:1: class=0x020000 card=0xa02c8086 chip=0x10e88086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82576 Gigabit Network Connection' class = network subclass = ethernet igb2@pci0:10:0:0: class=0x020000 card=0xa02c8086 chip=0x10e88086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82576 Gigabit Network Connection' class = network subclass = ethernet igb3@pci0:10:0:1: class=0x020000 card=0xa02c8086 chip=0x10e88086 rev=0x01 hdr=0x00 vendor = 'Intel Corporation' device = '82576 Gigabit Network Connection' class = network subclass = ethernet vgapci0@pci0:11:2:0: class=0x030000 card=0x823d1043 chip=0x002018ca rev=0x00 hdr=0x00 vendor = 'XGI Technology Inc. (eXtreme Graphics Innovation)' device = 'Z7/Z9 (XG20 core)' class = display subclass = VGA
