James Bean
- Dec 7, 2016
I apologise I have surfed google and the forums but didn't find a solution to my issue.
After a storm my cisco switch started dropping packets to everything, long story short, Cisco switch faulty, booted to the curb and new one installed.
All the devices (printers/pc's/routers/TV's) on the new switch can ping and talk to each other without packet loss, no issues, but I am getting 10% packet loss to my FreeNAS box.
Packet loss hits 30-40% if I start using the web interface (which starts dropping out), or transfer files off the samba shares.
Motherboard has a pair of Intel i210 nics, that were in load balance mode, I deleted this and configured the nics individually, same issue.
I had a spare Intel PRO/1000 PT Dual Port Server Adapter which I plugged into a PC and tested the ports were working first (which they were no issues), so I installed the card and set it up as individual nics and tested, still getting the same issues with packet loss as above. Pulled the card and installed in into my other workstation and it worked fine.
I used my Mikrotik Router to ping the FreeNAS box constantly and get the same results, although it was reporting "packet rejected" for most of the lost packets.
Twist is if I get on the console of the FreeNAS box and ping any device on the network, 0% packet loss, even while using the web interface from my PC (1000 ping tests at a time). This is while I get packet loss for the incoming packets from the router and my windows PC at the same time.
I have also tried resetting all the nic's, deleting all the lagg nic's and configuring each nic individually one at a time and testing, as well as brand new network cables.
So it doesn't sound like the NIC's are faulty, but I am not enough of a *nix expert to track the issue in FreeBSD, any help would be appreciated.
Output of ifconfig:-
Output of pciconf -lv
Specs:
FreeNAS 9.10.1-U4
Asrock E3C226D21 Intel Xeon i3-1220 v3 and 2 x 8Gb ECC DDR3 1600MHz
4 x WD40EFRX WD Red 4Tb in RAIDZ2 and 1 16Gb SanDisk USB (boot)
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO> ether 00:1f:29:57:0d:ae inet 192.168.69.10 netmask 0xffffff00 broadcast 192.168.69.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active em1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=4019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO> ether 00:1f:29:57:0d:af nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier igb0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether d0:50:99:6c:ab:6a nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO> ether d0:50:99:6c:ab:6b nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:de:f2:6b:95:00 nd6 options=1<PERFORMNUD> id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair6a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 13 priority 128 path cost 2000 member: epair5a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 12 priority 128 path cost 2000 member: epair4a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 11 priority 128 path cost 2000 member: epair3a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 10 priority 128 path cost 2000 member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 9 priority 128 path cost 2000 member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 7 priority 128 path cost 2000 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:07:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:08:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:09:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair3a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0a:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair4a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0b:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair5a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0c:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active epair6a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:20:00:0d:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
hostb0@pci0:0:0:0: class=0x060000 card=0x0c081849 chip=0x0c088086 rev=0x06 hdr=0x00 vendor = 'Intel Corporation' device = 'Xeon E3-1200 v3 Processor DRAM Controller' class = bridge subclass = HOST-PCI pcib1@pci0:0:1:0: class=0x060400 card=0x0c011849 chip=0x0c018086 rev=0x06 hdr=0x01 vendor = 'Intel Corporation' device = 'Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller' class = bridge subclass = PCI-PCI xhci0@pci0:0:20:0: class=0x0c0330 card=0x8c311849 chip=0x8c318086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family USB xHCI' class = serial bus subclass = USB none0@pci0:0:22:0: class=0x078000 card=0x8c3a1849 chip=0x8c3a8086 rev=0x04 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family MEI Controller' class = simple comms none1@pci0:0:22:1: class=0x078000 card=0x8c3b1849 chip=0x8c3b8086 rev=0x04 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family MEI Controller' class = simple comms ehci0@pci0:0:26:0: class=0x0c0320 card=0x8c2d1849 chip=0x8c2d8086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family USB EHCI' class = serial bus subclass = USB pcib2@pci0:0:28:0: class=0x060400 card=0x8c101849 chip=0x8c108086 rev=0xd5 hdr=0x01 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family PCI Express Root Port' class = bridge subclass = PCI-PCI pcib3@pci0:0:28:2: class=0x060400 card=0x8c141849 chip=0x8c148086 rev=0xd5 hdr=0x01 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family PCI Express Root Port' class = bridge subclass = PCI-PCI pcib4@pci0:0:28:3: class=0x060400 card=0x8c161849 chip=0x8c168086 rev=0xd5 hdr=0x01 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family PCI Express Root Port' class = bridge subclass = PCI-PCI pcib5@pci0:0:28:7: class=0x060400 card=0x8c1e1849 chip=0x8c1e8086 rev=0xd5 hdr=0x01 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family PCI Express Root Port' class = bridge subclass = PCI-PCI ehci1@pci0:0:29:0: class=0x0c0320 card=0x8c261849 chip=0x8c268086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family USB EHCI' class = serial bus subclass = USB isab0@pci0:0:31:0: class=0x060100 card=0x8c561849 chip=0x8c568086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = 'C226 Series Chipset Family Server Advanced SKU LPC Controller' class = bridge subclass = PCI-ISA ahci0@pci0:0:31:2: class=0x010601 card=0x8c021849 chip=0x8c028086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode]' class = mass storage subclass = SATA none2@pci0:0:31:3: class=0x0c0500 card=0x8c221849 chip=0x8c228086 rev=0x05 hdr=0x00 vendor = 'Intel Corporation' device = '8 Series/C220 Series Chipset Family SMBus Controller' class = serial bus subclass = SMBus em0@pci0:1:0:0: class=0x020000 card=0x7044103c chip=0x105e8086 rev=0x06 hdr=0x00 vendor = 'Intel Corporation' device = '82571EB Gigabit Ethernet Controller' class = network subclass = ethernet em1@pci0:1:0:1: class=0x020000 card=0x7044103c chip=0x105e8086 rev=0x06 hdr=0x00 vendor = 'Intel Corporation' device = '82571EB Gigabit Ethernet Controller' class = network subclass = ethernet igb0@pci0:3:0:0: class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00 vendor = 'Intel Corporation' device = 'I210 Gigabit Network Connection' class = network subclass = ethernet igb1@pci0:4:0:0: class=0x020000 card=0x15331849 chip=0x15338086 rev=0x03 hdr=0x00 vendor = 'Intel Corporation' device = 'I210 Gigabit Network Connection' class = network subclass = ethernet pcib6@pci0:5:0:0: class=0x060400 card=0x11501849 chip=0x11501a03 rev=0x02 hdr=0x01 vendor = 'ASPEED Technology, Inc.' device = 'AST1150 PCI-to-PCI Bridge' class = bridge subclass = PCI-PCI vgapci0@pci0:6:0:0: class=0x030000 card=0x20001849 chip=0x20001a03 rev=0x21 hdr=0x00 vendor = 'ASPEED Technology, Inc.' device = 'ASPEED Graphics Family' class = display subclass = VGA
Specs:
FreeNAS 9.10.1-U4
