Summary:
I've been running this particular FreeNAS system since January of this year and recently added a spare Chelsio T3 10GbE card for direct connection (no switch involved) to a workstation. At the time of install, the hardware was running FreeNAS-9.3-STABLE-201503200528. I directly connected the two systems using a SFP+ DAC cable -- the system on the other end has a Qlogic dual port 10GbE card in it -- and configured both sides of the link with a static IP address. Connectivity over the direct link was working well after this and I was able to transfer data over the link in excess of several hundred megabytes per second as expected. I was using this configuration for several days without incident; the workstation was powered down daily breaking the link, but it always came up the next time the workstation was turned on.
Today, the FreeNAS system was updated to FreeNAS-9.3-STABLE-201503270027 (no hardware was touched) and now the link between the systems is only functional for a short time while FreeNAS boots. After a certain point in the boot process, it is almost as if a firewall has come up - the link still appears to be up and active on both sides, but pings in either direction fail. A ping started while the FreeNAS system is booting responds normally at first, but consistently stops working right after the FreeNAS console shows, "Starting ntpd." Once the next lines of "Importing account for <user>...ok" messages start appearing, ping starts returning "Destination Host Unreachable". I tried booting the previous version of FreeNAS that it was running on before but the behavior persisted. I have reseated the cable, reconfigured the interfaces from scratch, disabled and re-enabled the interface on either side, rebooted both systems countless times yet can't get the link working again.
Anyone have any insights as to what might be happening here? I've swapped out the Chelsio T3 card with another similar card and got the same results. Just to rule out a problem on the other side of the link, I swapped out the Qlogic card on that end as well. The behavior doesn't change - there is connectivity initially, which is subsequently lost once the boot process gets to a certain point.
Any pointers as to what my next troubleshooting steps should be would be greatly appreciated. I'm at a loss as to what I've screwed up here since it was all working great prior to today's reboot.
Thanks in advance!
Regards,
Michael
I had a working 10GbE connection between a FreeNAS box and separate dual boot Windows/Linux system that ceased functioning after updating the FreeNAS box. Booting the previous version didn't restore functionality. I need some help troubleshooting! :)
Thanks in advance!
Regards,
Michael
Hardware
Motherboard: SuperMicro X10SL7-F
CPU: Intel Xeon E3-1270 v3
Memory: Crucial 16GB (8GBx2) ECC
Network: Onboard Intel GbE
Network (add-on): Chelsio T3 10GbE
Power Supply: Seasonic 500w
Boot Device: SATA DoM
Storage: WD Red (x4) in RAIDZ2
Other Notes: Onboard LSI 2308 Flashed IT, v16 firmware
Software: FreeNAS-9.3-STABLE-201503270027
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v3 Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x8 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C222 Series Chipset Family Server Essential SKU LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
00:1f.6 Signal processing controller: Intel Corporation 8 Series Chipset Family Thermal Management Controller (rev 05)
01:00.0 Ethernet controller: Chelsio Communications Inc S310-CR 10GbE Single Port Adapter
02:00.0 Serial Attached SCSI controller: LSI Logic / Symbios Logic SAS2308 PCI-Express Fusion-MPT SAS-2 (rev 05)
03:00.0 PCI bridge: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge (rev 03)
04:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 30)
05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
06:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
hostb0@pci0:0:0:0: class=0x060000 card=0x080415d9 chip=0x0c088086 rev=0x06 hdr=0x00
vendor = 'Intel Corporation'
class = bridge
subclass = HOST-PCI
pcib1@pci0:0:1:0: class=0x060400 card=0x080415d9 chip=0x0c018086 rev=0x06 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib2@pci0:0:1:1: class=0x060400 card=0x080415d9 chip=0x0c058086 rev=0x06 hdr=0x01
class = bridge
subclass = PCI-PCI
none0@pci0:0:20:0: class=0x0c0330 card=0x080415d9 chip=0x8c318086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
ehci0@pci0:0:26:0: class=0x0c0320 card=0x080415d9 chip=0x8c2d8086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
pcib3@pci0:0:28:0: class=0x060400 card=0x080415d9 chip=0x8c108086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib5@pci0:0:28:2: class=0x060400 card=0x080415d9 chip=0x8c148086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
pcib6@pci0:0:28:3: class=0x060400 card=0x080415d9 chip=0x8c168086 rev=0xd5 hdr=0x01
class = bridge
subclass = PCI-PCI
ehci1@pci0:0:29:0: class=0x0c0320 card=0x080415d9 chip=0x8c268086 rev=0x05 hdr=0x00
class = serial bus
subclass = USB
isab0@pci0:0:31:0: class=0x060100 card=0x080415d9 chip=0x8c528086 rev=0x05 hdr=0x00
class = bridge
subclass = PCI-ISA
ahci0@pci0:0:31:2: class=0x010601 card=0x080415d9 chip=0x8c028086 rev=0x05 hdr=0x00
class = mass storage
subclass = SATA
none1@pci0:0:31:3: class=0x0c0500 card=0x080415d9 chip=0x8c228086 rev=0x05 hdr=0x00
class = serial bus
subclass = SMBus
none2@pci0:0:31:6: class=0x118000 card=0x080415d9 chip=0x8c248086 rev=0x05 hdr=0x00
class = dasp
cxgbc0@pci0:1:0:0: class=0x020000 card=0x00011425 chip=0x00351425 rev=0x00 hdr=0x00
vendor = 'Chelsio Communications Inc'
device = 'S310-CR 10GbE Single Port Adapter'
class = network
subclass = ethernet
mps0@pci0:2:0:0: class=0x010700 card=0x069115d9 chip=0x00861000 rev=0x05 hdr=0x00
vendor = 'LSI Logic / Symbios Logic'
device = 'SAS2308 PCI-Express Fusion-MPT SAS-2'
subclass = SAS
pcib4@pci0:3:0:0: class=0x060400 card=0x080415d9 chip=0x11501a03 rev=0x03 hdr=0x01
vendor = 'ASPEED Technology, Inc.'
device = 'AST1150 PCI-to-PCI Bridge'
class = bridge
subclass = PCI-PCI
vgapci0@pci0:4:0:0: class=0x030000 card=0x080415d9 chip=0x20001a03 rev=0x30 hdr=0x00
device = 'ASPEED Graphics Family'
class = display
subclass = VGA
igb0@pci0:5:0:0: class=0x020000 card=0x153315d9 chip=0x15338086 rev=0x03 hdr=0x00
class = network
subclass = ethernet
igb1@pci0:6:0:0: class=0x020000 card=0x153315d9 chip=0x15338086 rev=0x03 hdr=0x00
class = network
subclass = ethernet
class = bridge
subclass = HOST-PCI
class = bridge
subclass = PCI-PCI
class = bridge
subclass = PCI-PCI
class = serial bus
subclass = USB
class = serial bus
subclass = USB
class = bridge
subclass = PCI-PCI
class = bridge
subclass = PCI-PCI
class = bridge
subclass = PCI-PCI
class = serial bus
subclass = USB
class = bridge
subclass = PCI-ISA
subclass = SATA
class = serial bus
subclass = SMBus
class = dasp
class = network
subclass = ethernet
subclass = SAS
class = bridge
subclass = PCI-PCI
class = display
subclass = VGA
class = network
subclass = ethernet
class = network
subclass = ethernet
mhobbes@nas:~ % ifconfig cxgb0 cxgb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6c07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:07:43:06:bc:ad inet 10.0.5.50 netmask 0xffffff00 broadcast 10.0.5.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet 10Gbase-Twinax <full-duplex> status: active
mhobbes@workstation ~ $ ping nas10 PING nas10 (10.0.5.50) 56(84) bytes of data. 64 bytes from nas10 (10.0.5.50): icmp_seq=16 ttl=64 time=998 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=17 ttl=64 time=0.056 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=18 ttl=64 time=0.090 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=19 ttl=64 time=0.111 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=20 ttl=64 time=0.104 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=21 ttl=64 time=0.105 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=22 ttl=64 time=0.100 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=23 ttl=64 time=0.097 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=24 ttl=64 time=0.091 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=25 ttl=64 time=0.091 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=26 ttl=64 time=0.093 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=27 ttl=64 time=0.113 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=28 ttl=64 time=0.109 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=29 ttl=64 time=0.100 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=30 ttl=64 time=0.099 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=31 ttl=64 time=0.093 ms 64 bytes from nas10 (10.0.5.50): icmp_seq=32 ttl=64 time=0.095 ms From nas10 (10.0.5.50) icmp_seq=59 Destination Host Unreachable From nas10 (10.0.5.50) icmp_seq=60 Destination Host Unreachable From nas10 (10.0.5.50) icmp_seq=61 Destination Host Unreachable From nas10 (10.0.5.50) icmp_seq=62 Destination Host Unreachable From nas10 (10.0.5.50) icmp_seq=63 Destination Host Unreachable From nas10 (10.0.5.50) icmp_seq=64 Destination Host Unreachable ^C --- nas10 ping statistics --- 65 packets transmitted, 17 received, +6 errors, 73% packet loss, time 64118ms rtt min/avg/max/mdev = 0.056/58.800/998.059/234.814 ms, pipe 4
mhobbes@nas:~ % arp -a nas (10.0.4.50) at 0c:c4:7a:c2:d1:d8 on igb0 permanent [ethernet] ? (10.0.5.25) at 78:e3:b5:f4:c3:d2 on cxgb0 expires in 977 seconds [ethernet] nas10 (10.0.5.50) at 00:07:43:06:bc:ad on cxgb0 permanent [ethernet]
mhobbes@workstation ~ $ ifconfig eth2 eth2 Link encap:Ethernet HWaddr 78:e3:b5:f4:c3:d2 inet addr:10.0.5.25 Bcast:10.0.5.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:23 errors:0 dropped:0 overruns:0 frame:0 TX packets:200 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2276 (2.2 KB) TX bytes:26202 (26.2 KB) Interrupt:48
