So I've upgraded to 8.2-RELEASE-p1 in my virtual machine and I've started playing with the jail. I've setup the jail and I have successfully logged into the jail. I get the alert that the IP address for the jail is unreachable so the plugs will not work.
So I logged into the jail (jexec 1 csh) and I cannot ping my router. I then logged out of the jail and tried to ping the jail IP. It was not reachable. I am sure my subnet is correct (255.255.255.0). I have tried adding plugins but I just get more errors relating to the fact that the jail IP cannot be found. Right now I have no plugins installed yet. I figured troubleshooting would be easier with just the jail installed.
Here's some other odd things that MAY help identify the issue. I haven't been able to resolve these quirks.
1. I have noticed that I cannot access the NTP servers that are defaulted in FreeNAS. I added the one that is somewhat local to me (Chicago, IL) but I still have to "force" it because I get an error that the NTP cannot be contacted. Of course, if I were to ping www.google.com it works perfectly. I do not know if NTP servers are being blocked by a firewall(my router, my symantec antivirus on the host OS has the firewall disabled at the moment for other unrelated reasons) or if there is something wrong with the NTP service in FreeNAS because it is a guest OS in a VMWare virtual machine. I seem to remember there used to be weird things that would go on when a guest machine tried to change the time or date because the guest time/date is supposed to be in sync with the host OS.
2. My network(in particular, my router) does not support IPv6. I've disabled the service on all of my my workstations and the machines that FreeNAS runs as a guest on. Yet, when I bootup after I installed the jail I get these errors in the log at the bottom of the UI....
FreeNAS kernel: bridge0: Ethernet address: 76:77:11:ab:e4:24
FreeNAS kernel: epair0a: Ethernet address: 02:20:82:00:04:0a
FreeNAS kernel: epair0b: Ethernet address: 02:20:82:00:05:0b
FreeNAS kernel: epair0a: link state changed to UP
FreeNAS kernel: epair0b: link state changed to UP
FreeNAS kernel: epair0a: promiscuous mode enabled
FreeNAS kernel: em0: promiscuous mode enabled
FreeNAS kernel: epair0b: DAD detected duplicate IPv6 addres fe80:2::20:82ff:fe00:50b: NS in/out=1/1, NA in=0
FreeNAS kernel: epair0b: DAD complete for fe80:2::20:82ff:fe00:50b - duplicate found
FreeNAS kernel: epair0b: manual intervention required
FreeNAS kernel: epair0b: possible hardware address duplication detected, disable IPv6
FreeNAS ntpd[1564]: time reset +9.314228 s
Keep in mind my FreeNAS server uses DHCP for it's address, but it is setup as a static IP in my router DHCP settings. I'm also confused because IPv6 isn't supported in the jail from what I've read but an error(shown below) says to disable IPv6.
So can anyone tell me what I am doing wrong? Here's the ifconfig for my FreeNAS server:
Here's the ifconfig for my jail:
Any ideas? I've been scratching my head at this for 18 hours, watched a youtube video from protosd, read the manual for the applicable sections, and searched the forum for other people with similar situations. No help at all :(
On another note.. maybe we should add a section of the FreeNAS Help and support forum for Jail and plugin issues. I really wasn't sure where I should put my issue, so I figured I'd try here.
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
ether 00:0c:29:12:78:8f
inet 192.168.0.99 netmask 0xffffff00 broadcast 192.168.0.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
inet6 ::1 prefixlen 128
nd6 options=3<PERFORMNUD,ACCEPT_RTADV>
ether 06:d8:58:7a:ff:26
maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 2000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:08:d8:00:04:0a
status: active
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:08:d8:00:05:0b
inet 192.168.0.98 netmask 0xffffff00 broadcast 192.168.0.255
inet6 fe80::8:d8ff:fe00:50b%epair0b prefixlen 64 duplicated scopeid 0x2
nd6 options=b<PERFORMNUD,ACCEPT_RTADV,IFDISABLED>
status: active
