electricwildflower
- Jan 18, 2019
Hi everyone, i have two issues that i need help with
I had a Network issue over the weekend with my router which involved me having to factory reset my router and go through the motions of re doing all my settings, port forwarding, static ip's etc, whilst i did this the server decided it was no longer going to connect IE i couldn't access web gui, ping server, browse samba shares etc, i finally accessed it and got a database back up due to the fact i had a new SSD i was going to swap out for the old one. I got Truenas scale (latest version installed) installed and used the database backup file and it seemed to go well.
Once i got back onto the web gui i faced two issues
1 - One of my Pools Vol 5 which is a mirror of two 6 TB hard drives says it's unhealthy but shows 0 errors?
2 - Applications - All applications are either stuck on deploying or stopped and each one i am greeted with the error
"network is not ready: container runtime network not ready: NetworkReady=false reason:NetworkPluginNotReady message:docker: network plugin is not ready: cni config uninitialized"
If it helps all apps are installed to the Vol5 pool if that's the issue of app problems?
Thanks
"Pool Vol5 state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected."
Thanks
