Network drops after a degraded volume?
Raymond Matos
So i been getting emails every 5 mins about a volume being degraded. I havent had a chance to replace it.
More importantly, i get notification that the freenas server network is offline, then 2-3mins later its back. Im guessing its related, but i dont understand why a degraded volume would cause the network to drop in and out. Also why am i getting emails every 5 mins.
here is the dmesg log output
Build FreeNAS-9.10.1 (d989edd)
Platform Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
Memory 32623MB
log is here
https://gist.github.com/raymatos/c0b40e53560d5336d64cac6cf71b1fcb
SweetAndLow
Sweet'NASty
I didn't see anything in that log about network going down. What are these network notifications you are getting?
Raymond Matos
I have a service that pings the websites that i have running on freenas (ie: sabnzbd, couchpotato, etc) and send me a notification when it goes down.
Any reason why i would get an email every 5 mins? the email is from freenas regarding the degraded volume.
SweetAndLow
Sweet'NASty
You need to give us way more information. What is your pool layout, what is your freenas version, what hardware are you using(motherboard, cpu, ram, disks, controller). I suspect you have something setup wrong.
Raymond Matos
Here are the machine Specs
32631MB - ECC ram
SUPERMICRO MBD-X10SAE-O ATX Server Motherboard
M1015 out to an hp sas expander
3 different volumes
pool: ADE01
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 824K in 1h29m with 1 errors on Sat Sep 17 05:02:24 2016
NAME STATE READ WRITE CKSUM
ADE01 ONLINE 0 0 1
raidz2-0 ONLINE 0 0 4
gptid/57a0c0ab-4283-11e4-9185-00259086c202 ONLINE 0 0 0
gptid/584946a3-4283-11e4-9185-00259086c202 ONLINE 0 0 0
gptid/58f42459-4283-11e4-9185-00259086c202 ONLINE 0 0 0
gptid/5995e289-4283-11e4-9185-00259086c202 ONLINE 0 0 0
errors: 1 data errors, use '-v' for a list
pool: backup1
state: ONLINE
scan: scrub repaired 0 in 2h33m with 13 errors on Sat Sep 17 08:07:31 2016
backup1 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/edd5cd38-ba0e-11e3-922a-00259086c202 ONLINE 0 0 0
gptid/efd3abab-ba0e-11e3-922a-00259086c202 ONLINE 0 0 0
errors: 13 data errors, use '-v' for a list
pool: freenas-boot
state: ONLINE
scan: resilvered 541M in 0h8m with 0 errors on Fri Sep 16 19:37:03 2016
freenas-boot ONLINE 0 0 0
gptid/e9b1dad7-7c27-11e6-9d07-00259086c202 ONLINE 0 0 0
gptid/b9703b63-7c43-11e6-a3b1-00259086c202 ONLINE 0 0 0
errors: No known data errors
pool: jails
state: DEGRADED
scan: resilvered 1.35M in 0h0m with 0 errors on Wed Sep 21 14:56:14 2016
jails DEGRADED 0 0 125
mirror-0 DEGRADED 0 0 250
gptid/3c94e433-7c58-11e6-a900-00259086c202 DEGRADED 0 0 250 too many errors
6213643929067291486 UNAVAIL 30 67 89 was /dev/da23p2
pool: tank1
state: ONLINE
scan: resilvered 36K in 0h0m with 0 errors on Fri Sep 16 18:19:18 2016
tank1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/6d8f5cca-aa72-11e3-9202-00259086c202 ONLINE 0 0 0
gptid/6e64de8c-aa72-11e3-9202-00259086c202 ONLINE 0 0 0
gptid/6f3b878c-aa72-11e3-9202-00259086c202 ONLINE 0 0 0
gptid/7012ee03-aa72-11e3-9202-00259086c202 ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
gptid/27782ca0-f039-11e3-89c2-00259086c202 ONLINE 0 0 0
gptid/2857adb5-f039-11e3-89c2-00259086c202 ONLINE 0 0 0
gptid/29353ec9-f039-11e3-89c2-00259086c202 ONLINE 0 0 0
gptid/2a157610-f039-11e3-89c2-00259086c202 ONLINE 0 0 0
raidz2-2 ONLINE 0 0 0
gptid/5264f6c7-11ea-11e5-96e7-00259086c202 ONLINE 0 0 0
gptid/52d6cf71-11ea-11e5-96e7-00259086c202 ONLINE 0 0 0
gptid/539468f8-11ea-11e5-96e7-00259086c202 ONLINE 0 0 0
gptid/5406480f-11ea-11e5-96e7-00259086c202 ONLINE 0 0 0
raidz2-3 ONLINE 0 0 0
gptid/843b4ccd-7c5c-11e6-8555-00259086c202 ONLINE 0 0 0
gptid/853e00d6-7c5c-11e6-8555-00259086c202 ONLINE 0 0 0
gptid/863ce193-7c5c-11e6-8555-00259086c202 ONLINE 0 0 0
gptid/873b8b35-7c5c-11e6-8555-00259086c202 ONLINE 0 0 0
cache
gptid/5e8ede6e-4527-11e4-9fc5-00259086c202 ONLINE 0 0 0
errors: 3 data errors, use '-v' for a list
SweetAndLow
Sweet'NASty
Why do all your pools say 'Otherwise restore the entire pool from backup.'? This is usually very bad, at a minimum you have data loss and possibly loose everything in all your pools. Tell us more about your setup you are doing something that you are not telling us about.
Raymond Matos
This happens only when you have a corrupted file in a pool, you either restore the file from backup or delete it from the pool. After you run a scrub it should go away.
This has been setup and running for over 3 years now with no issue till now.
I pretty much gave you all the information on my setup, not hiding anything.
32631MB - ECC ram
total of 24 drives. Some are 3tb other are 2tb.
depasseg
FreeNAS Replicant
You are right, it wouldn't'. It's more likely that they have a similar root cause like system overheating or bad psu would be my guess.
