Needs Some Set up Help ( yes I'm a Newbie)
Ameggs
So after spending the last 4.5 hours trying to get this to work , along with searching for answers, I humble myself and ask for help. I have an:
intel dp55wb MB
I7 860 processor
10GB of Ram
4x 3tb HDD , with 2 more I will add soon
The problem:
FreeNAS only sees 2 of the 4 drives. I swapped around cables, tried to make sure the MOBO bios was configured correctly ( I think this is the issue) but i cant see to figure this out.
Spearfoot
He of the long foot
intel dp55wb MB
I7 860 processor
10GB of Ram
The problem:
Have you configured the BIOS to 'auto-configure' SATA devices? Perhaps you should try manually configuring these? Make sure you haven't configured the SATA system as RAID; FreeNAS needs direct access to the disks.
Good luck!
Spearfoot
He of the long foot
Oh... and Welcome to the Forums! :smile:
saif alaqqad
intel dp55wb MB
I7 860 processor
10GB of Ram
The problem:
The problem seems to be with your BIOS
Try updating the BIOS to the newest version
Here is your motherboard link : http://www.intel.com/content/www/us...esktop-boards/intel-desktop-board-dp55wb.html
Sent from my Pixel XL using Tapatalk
