The error is caused by SMART testing of the drive currently labeled as ada4
in your pool, pending unreadable sectors are generally an early failure indicator.
In MOST cases, replacement of the drive is the cure.
post results from
smartctl -a /dev/ada4
make sure to place the output in code tags.
Good luck!
