Hello I accidently made a mistake by removing on sata cable.
Now my zpool status is degraded.
Did a shutdown and installed the cable again but the status of the zpool is still degraded.
I Have now 2 disks with the same serial in my pool the name of both disks is ada1.
pool: freenas-volu
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://www.sun.com/msg/ZFS-8000-8A
scrub: none requested
NAME STATE READ WRITE CKSUM
freenas-volu DEGRADED 0 0 0
raidz1 DEGRADED 0 0 0
3642872288631289690 UNAVAIL 0 0 0 was /dev/ada0p2
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
freenas-volu:<0x95>
Any help would be appreciated.
pool: freenas-volu
state: DEGRADED
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
freenas-volu:<0x95>
