Hey all,
I'm in the process of swapping out a Dell R720 running our main TrueNAS system here with a Dell Compellent SC8000 where I'll have TrueNAS installed on an internal USB drive for boot instead of the hardware RAID boot pool it's using in the current system... I need to identify the actual SAS HBA card I'm using in the system so I can source a replacement and get that installed to send the system to get swapped, but as I don't have physical access I can't just shut down the system to open it up and check, and it doesn't show up in the iDRAC.
In the shell I've got:
Which seems to suggest that it's an LSI card, naturally my next command in the shell was sas2flash, etc...
So, now I'm stumped and hoping for some insights.
Cheers!
root@TrueNAS[~]# lspci|grep SAS 03:00.0 RAID bus controller: Broadcom / LSI MegaRAID SAS-3 3108 [Invader] (rev 02) 06:00.0 Serial Attached SCSI controller: Adaptec Smart Storage PQI SAS (rev 01)
root@TrueNAS[~]# sas2flash -listall LSI Corporation SAS2 Flash Utility Version 20.00.00.00 (2014.09.18) Copyright (c) 2008-2014 LSI Corporation. All rights reserved No LSI SAS adapters found! Limited Command Set Available! ERROR: Command Not allowed without an adapter! ERROR: Couldn't Create Command -listall Exiting Program. root@TrueNAS[~]# sas3flash -listall Avago Technologies SAS3 Flash Utility Version 16.00.00.00 (2017.05.02) Copyright 2008-2017 Avago Technologies. All rights reserved. No Avago SAS adapters found! Limited Command Set Available! ERROR: Command Not allowed without an adapter! ERROR: Couldn't Create Command -listall Exiting Program. root@TrueNAS[~]# sas2ircu LIST LSI Corporation SAS2 IR Configuration Utility. Version 20.00.00.00 (2014.09.18) Copyright (c) 2008-2014 LSI Corporation. All rights reserved. SAS2IRCU: MPTLib2 Error 1 root@TrueNAS[~]# sas3ircu LIST Avago Technologies SAS3 IR Configuration Utility. Version 16.00.00.00 (2017.04.26) Copyright (c) 2009-2017 Avago Technologies. All rights reserved. SAS3IRCU: MPTLib2 Error 1
Cheers!
