Charles Weeks
 - Feb 16, 2014
I know the responses will be a bit biased here ;) but please show me the light!
Ive done some searching on both but all of the comparisons I have found involve old versions. Below is the gear I have for the build and what I'm needing the rig to handle.
Build Gear
MOBO: Supermicro X8DAH+-F
CPU: 2x Intel Xeon CPU L5639 @ 2.13GHz
RAM: 64GB
CONTROLLERS: Integrated Intel for boot if needed (Depending on OS Selection)
3x LSI 9201-16i
CHASSIS: AIC RSC-5D 5U 48 bays top load (older version with SAS 3g backplane)
HDD: Still up in the air but probably Toshiba 3TB
ZFS CONFIG
(2) Pools - (4) RaidZ2 vdevs of (6) drives each spread across the three lsi controllers
Goals
Media Storage Server (File types mostly comprised of 1080p mkv and iso)
Sync to Second Local Server for backup (I want this to be weekly incremental file copy)
-not sure how to achieve this rsync? but i want data to be readily accessible without any recovery steps needed...just point to a new share and go
Run MySQL for central XBMC database
Simple User Interface for daily operation and also recovery
My current rig is a Frankenstein monster( 43Tb usable) of every recommended thing to avoid for zfs (raid cards, sas expanders, etc) and I want to make this one correct or as correct as my budget can allow. I have all the above gear and I'm only missing the drives.
I need some guidance from you guys on OS choice and drives.
OS's I'm considering
OmniOS with napp-it
OpenIndiana with napp-it --> currently using
FreeNAS 9.2.1
I'm leaning towards FreeNAS but dont have any extensive experience with it beyond a couple weeks of testing with 10 spare 2 TB drives I have laying around. I know Gea is focusing on OmniOS moving forward with napp-it but I'm apprehensive on giving up my desktop environment cause it has saved my butt a few times (track down issues that i would have been lost doing via cli)
Point me in the right direction guys. Thanks
Build Gear
RAM: 64GB
3x LSI 9201-16i
ZFS CONFIG
Goals
OmniOS with napp-it
FreeNAS 9.2.1
