Arthur Hanlon
- Mar 20, 2017
Hi all,
Not sure where to go with this one but I am getting spammed by my Freenas box with emails with the title above which seems to be referencing a script that used to run under CRON but not longer does and I can't for the life of me figure out what's generating these emails? To be frank, I'm not even sure where to start but the title of the email is:
"Cron <root@freenas> PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bi n" /root/temps.sh > /dev/null"
temps.sh was a shell script that I used to use to push hard drive and CPU temps to a graphite server for a period of time. It does have the hostname of the graphite server in it and when I check this on the Freenas box at the commend line using DIG or DRILL it resolves perfectly fine.
Currently running 11.2-U4 on a Gen8 Microserver and gateway and DNS servers are set correctly, not sure what other information I should provide, if any though.
Cheers
Cheers
