Can't get cron to work!!
windyboi
Hi, I'm trying to get the following cron job to run, set up through the Freenas GUI:
scp freenas@192.168.10.1:/cf/conf/config.xml /mnt/my_pool/Data/Backups/pfsense/`date +\%Y\%m\%d\%H\%M\%S`-config-fw.xml
But each night it shows it fails by emailing me:
Email title: Cron <root@kenny> PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" scp freenas@192.168.10.1:/cf/conf/config.xml /mnt/my_pool/Data/Backups/pfsense/`date +\
Email contents:
/bin/sh: Syntax error: EOF in backquote substitution
/bin/sh: Syntax error: Error in command substitution
Anyone able to spot the problem? It works fine when I execute it from the command line directly
Thank you!
m0nkey_
Try putting your command in a script, then use cron to call the script.
#!/usr/bin/env sh
Chris Moore
Agree with @m0nkey_ , the slashes in the date format is what caused the error, not because it is wrong, and throwing it in a script is the easy way to fix it.
It probably needs an extra set of quotes around it or something silly to keep the system from prematurely interpreting the slashes in the date format.
wblock
Documentation Engineer
I don't see why the percent signs in the date format are being escaped. Put single quotes around the date format and remove the backslashes.
And remember: always use full paths in cron jobs. Including full paths to commands.
