Hi all,
Sorry for the vague title. Couldn't think of something better at the moment. So here is my situation, I've got a Windows 10 Pro PC which works as it should.
When I navigate to \\*myfreenasip* then I see all the shared folders. 2 of them are password protected and 1 of them has the guest allowed setting. This is how I want it to be set up.
I also have another laptop with Windows 10 Enterprise and when I try to go too \\*myfreenasip* then I am prompted for a password.
Same for my girlfriends Windows 10 Pro laptop
I do not want this. I want to see the available shares without a need for a password. Why does it act like this and how do I solve it?
What have I done:
I checked the network settings on both my PC which is working and my laptop. They are identical as far as I can see
When I navigate to the guest accessible folder directly ( \\*myfreenasip\guest ) on the laptop I still get prompted for a password
Restarted SMB service on FreeNAS server
remade the Shares within FreeNAS
Permission type for my MediaVolume is set to Windows.
Restarted Windows Machines multiple times. Didn't restarted FreeNAS server yet.
FreeNAS is running on my HP Microserver Gen8 with the standard 4GB of RAM and Intel Celeron CPU. (Not that this has any to do with the problem)
FreeNAS11 Update 4
I most likely need to provide more information but don't what I could.
Thank you!
edit:
FreeNAS reboot didn't work either. Still works on my PC but not on my laptop
What have I done:
FreeNAS11 Update 4
Thank you!
edit:
