Nas daemon[3105]: ... [WARN] agent: Check 'freenas_health' is now warning
Niktronics
FreeNAS-11.1-U1, The status light is
search
GREEN , but I see this in the console area
Jan 27 23:40:31 Nas daemon[3105]: 2018/01/27 23:40:31 [WARN] agent: Check 'freenas_health' is now warning
Jan 27 23:42:32 Nas daemon[3105]: 2018/01/27 23:42:32 [WARN] agent: Check 'freenas_health' is now warning
Jan 27 23:44:32 Nas daemon[3105]: 2018/01/27 23:44:32 [WARN] agent: Check 'freenas_health' is now warning
Jan 27 23:46:32 Nas daemon[3105]: 2018/01/27 23:46:32 [WARN] agent: Check 'freenas_health' is now warning
Jan 27 23:48:33 Nas daemon[3105]: 2018/01/27 23:48:33 [WARN] agent: Check 'freenas_health' is now warning
What is Warning about? How do I fix it?
Redcoat
It's a bug in 11.1-U1, it will be fixed in next update. See this thread for more info.
Niktronics
diavigne just ask you fix the "warning msg thing Nas daemon[3105]. If anyone has a solution they can share with you the answer.
I like Freenas, and if we talk more maybe find the solutions faster.
Did anybody found why this is happening ?
This is on fresh new install, every 2 minutes.
D
dlavigne
Guest
As mentioned above, it's a bug that will be fixed in the next update.
Chris Moore
Did you look at the thread reference @Redcoat gave you?
There is a fix to stop the log spam.
Read up that thread, maybe a dozen posts.
Thanks,but I am thinking to go back to Freenas 9.3, cause this 11.1 has to to many bug probably to dealt with.It's my first install of Freenas 11.1 and already 2 issues just from install to finish:
From the beginning of installation starting with the first pic and after the install is complete you got the that.
I forgot to upload after the install pic. Here it is:
But thanks anyway.
So the fix for spam in your logs is to revert to a three-year-old release? I get that it's annoying, but that seems more than a little excessive.
Chris Moore
You literally just paste these four lines in at the command prompt and it stops the log spam. Done. What other problem are you talking about?
cd /usr/local/etc/consul-checks/
rm freenas*
wget https://raw.githubusercontent.com/freenas/freenas/8175ddd35c189c43c47a51e42a1353e96d9ac2cb/src/freenas/usr/local/etc/consul-checks/freenas_health.sh
chmod a+x freenas_health.sh
Well, until you reboot, anyway. But seriously, what's the big deal? I guess if you're just reading through your logs on a regular basis, it would get in the way--but other than that, grep is your friend.
Oh is not just that, I wish was just that. I give it a some try every year, so I don't miss on something better. I tried version 10, then when back, then there was "coral" somewhere, then when back, there were something before 11.1 I remember the freezing new gui that I went back again. I find stability and reliability to be much more important "improvement direction" , compared to jails, plex or using freenas as hypervisor. It's just not what I felt in love with freenas originally. It just my opinion.
rm freenas*
I appreciate you help, Honestly. The other issue was the other screenshot. I just posted 2 cause these I got just from install to finish , I haven't mess with it longer to find out what else is not right. No offense to anybody.
P.S. Since you ask, I just notice I can't connect to SSH with putty as before. I did enable SSH and allow "Login as Root with password:" same as before. Here is screenshot.
