Naming differs on Freenas and Share - help!
GrahamBB
I thought I understood shares, but this has bamboozled me. I set up a home server about a year ago and the shares are all working fine - exactly as expected. So I set up a Linux machine and try and connect it to what (I think) are the shares on Freenas. It turns out that the /mnt folder has completely different naming. I'm at a bit of a loss, and want to correct this but need to understand first. Any help most welcome!
All machines connect via the path nerdygirl/NerdHouse/Etc........
BUT
looking at the /mnt folder I see:
[root@nerdygirl] /mnt/HomePool# ls -al
total 71
drwxrwxr-x+ 5 graham wheel 6 May 22 2017 ./
drwxr-xr-x 3 root wheel 128 Dec 10 13:13 ../
-rw-r--r-- 1 root wheel 0 May 18 2017 .windows
drwxrwxr-x+ 14 root wheel 16 Dec 23 13:30 HeddaGobble/
drwxrwxr-x+ 2 graham wheel 3 May 18 2017 NerdHouse/
drwxr-xr-x 2 root wheel 2 May 22 2017 jails/
and all the folders and files are in HeddaGobble and NerdHouse is empty. HeddaGobble does NOT appear in the browsing path from any machine browsing the available shares.
GrahamBB
If I'm understanding your request properly:
You aren't. That's the storage configuration; the shares would be under Sharing, then click on Windows (SMB).
GrahamBB
.....and there it is. Duh!!!
Thanks
