rwfitzy
- Nov 20, 2014
I had nagios4 installed from when this jail was setup on my FreeNAS 11.1, but was having issues with plugins and removed all as I wanted to reinstall. But now, nagios4 will not install...
I do not see freebsd:11:x86:64 on pkg.FreeBSD.org, but I do see nagios4 in the same location under FreeBSD:11:amd64. I've tried
If I try to build manually from the ports tree, I get the following while the nagios-plugins package and others install without issue successfully:
root@monitor:/usr/local/etc # pkg install nagios4 Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. Updating database digests format: 100% The following 2 package(s) will be affected (of 0 checked): New packages to be INSTALLED: nagios4: 4.3.4_1,1 php56-xml: 5.6.36_1 Number of packages to be installed: 2 The process will require 7 MiB more space. 1 MiB to be downloaded. Proceed with this action? [y/N]: y pkg: http://pkg.FreeBSD.org/freebsd:11:x86:64/latest/All/nagios4-4.3.4_1,1.txz: Not Found
pkg update, which indicates all repos up to date, and portsnap fetch update. Can someone suggest how I can get this package installed?If I try to build manually from the ports tree, I get the following while the nagios-plugins package and others install without issue successfully:
root@monitor:/usr/ports/net-mgmt/nagios4 # make /!\ ERROR: /!\ Ports Collection support for your FreeBSD version has ended, and no ports are guaranteed to build on this system. Please upgrade to a supported release. No support will be provided if you silence this message by defining ALLOW_UNSUPPORTED_SYSTEM. *** Error code 1 Stop. make[1]: stopped in /usr/ports/net-mgmt/nagios4 *** Error code 1 Stop. make: stopped in /usr/ports/net-mgmt/nagios4
