My Pool got messed up, please help!
RobbieG1977
So I am thinking I lost all my data as I replaced 2 drives and now I can't seem to get the volume that I had back. Here is the error I get when I try and import the ZFS Volume. Not understanding what the error means, does it mean my data is gone and I have to start over?
Thanks!
Request Method: POST
Request URL: http://192.168.1.109/storage/auto-import/
Software Version: FreeNAS-11.1-U6 (caffd76fa)
Exception Type: MiddlewareError
Exception Value:
[MiddlewareError: The volume "RobzData" failed to import, for futher details check pool status]
Exception Location: ./freenasUI/middleware/notifier.py in volume_import, line 2650
Server time: Wed, 29 Aug 2018 18:29:50 -0700
Traceback
Request information
GET
No GET data
POST
Variable Value
auto_import_wizard-current_step '2'
2-__all__ ''
2-volume_id 'RobzData|14416566715175262580'
__form_id 'dijit_form_Form_16'
FILES
No FILES data
COOKIES
Variable Value
csrftoken '********'
sessionid 's0r1q4c9bgwmdausr0y6av2m8du6y59o'
fntreeSaveStateCookie 'root%2Croot%2F128%2F138%2Croot%2F188%2Croot%2F191%2Croot%2F208%2F214%2F216%2Croot%2F208%2F219%2F221%2Croot%2F208%2F224%2F226%2Croot%2F208%2F229%2F231%2Croot%2F156%2F162%2Croot%2F152%2Croot%2F92%2Croot%2F92%2F102%2Croot%2F173%2F179%2F181%2Croot%2F173%2F179%2Croot%2F172%2Croot%2F164%2Croot%2F176%2Croot%2F46%2Croot%2F61%2Croot%2F61%2F62%2Croot%2F61%2F62%2F63%2Croot%2F10%2Croot%2F93%2F103%2Croot%2F60%2F61%2Croot%2F45%2Croot%2F45%2F47%2Croot%2F59'
META
Variable Value
kdragon75
We need all the details of your system and the pool configuration.
RobbieG1977
I had too many hard drive failures that I indeed lost all my data. One of those drives was the one I installed the OS on. Sorry for the delayed response.
gpsguy
Active Member
I readlize you had several hard disk failures. But, recovering from a bad boot drive is usually a trivial task.
If you plan to rebuild your FreeNAS server, you might want to ask the community for input on your system. Perhaps you are doing something that adds risk.
