fx24
 - Sep 27, 2013
I am running FreeNAS 9.2.1.7. Today I received 8x WD Reds (6TB). I boot up and all 8 drives are recognized.
Going into ZFS Volume Manager I go to create a RAIDZ2 with all 8 drives. The Volume Manager estimates it to create 32.74TB, and when it creates the volume, it is only 30.4TB.
6TB lost, so that is losing nearly 1TB per usable disk. I have never seen that significant of a difference before so I hope that is normal.
As it created the pool, a windows popped up with this message:
I am not sure what to make of this. This pops up whether I make a RZ2, RZ3 or Stripe, optimal or not.
I am going to begin the burn-in process now.
[*]Request Method: POST [*]Request URL: http://192.168.0.21/storage/volumemanager/ [*]Software Version: FreeNAS-9.2.1.7-RELEASE-x64 (fdbe9a0) [*]Exception Type: OSError [*]Exception Value: [*][Errno 2] No such file or directory: '/mnt/cache/.system' [*]Exception Location: /usr/local/www/freenasUI/../freenasUI/middleware/notifier.py in system_dataset_create, line 5023 [*]Server time: Mon, 25 Aug 2014 21:27:27 -0700
Environment:
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
  107.                     response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
  158.         return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  22.                 return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/views.py" in volumemanager
  142.         if form.is_valid() and form.save():
File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in save
  463.         notifier().restart("system_datasets")
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in restart
  363.         self._simplecmd("restart", what)
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in _simplecmd
  239.         f()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in _restart_system_datasets
  4905.         systemdataset = self.system_dataset_create()
File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py" in system_dataset_create
  5023.                 os.chmod('/mnt/%s' % dataset, 0755)
Exception Type: OSError at /storage/volumemanager/
Exception Value: [Errno 2] No such file or directory: '/mnt/cache/.system'Code:
Request information GET No GET data POST Variable Value layout-0-vdevtype u'raidz2' __form_id u'dijit_form_Form_13' layout-0-disks u'ada7' __all__ u'' layout-TOTAL_FORMS u'1' layout-INITIAL_FORMS u'0' volume_name u'media' layout-__all__ u'' FILES No FILES data COOKIES Variable Value csrftoken 'Fb9x5rm1IUYRIa46yn0WVhF52N82SfgF' sessionid 'noqontbtsr19k3oph2s0kkn61yxylhxi' fntreeSaveStateCookie 'root%2Croot%2F202%2F208%2Croot%2F202%2F213%2Croot%2F202%2F208%2F210%2Croot%2F202%2F213%2F215%2Croot%2F53%2F60%2F129%2Croot%2F207%2F213%2F215%2Croot%2F207%2F218%2F220%2Croot%2F207%2F223%2Croot%2F207%2F223%2F225%2Croot%2F207%2F218%2Croot%2F207%2F213%2Croot%2F180%2Croot%2F180%2F186%2Croot%2F181%2F197%2Croot%2F53%2F60%2F105%2Croot%2F53%2F60%2F101%2Croot%2F1%2F6%2Croot%2F1%2F2%2Croot%2F10%2F26%2Croot%2F10%2F30%2Croot%2F37%2F39%2Croot%2F82%2F89%2Croot%2F53%2F60' META Variable Value wsgi.multiprocess False HTTP_REFERER 'http://192.168.0.21/' REDIRECT_STATUS '200' SERVER_SOFTWARE 'nginx/1.4.4' SCRIPT_NAME u'' HTTP_X_CSRFTOKEN 'Fb9x5rm1IUYRIa46yn0WVhF52N82SfgF' REQUEST_METHOD 'POST' PATH_INFO u'/storage/volumemanager/' HTTP_ORIGIN 'http://192.168.0.21' SERVER_PROTOCOL 'HTTP/1.1' QUERY_STRING '' CONTENT_LENGTH '300' HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/36.0.1985.143 Safari/537.36' HTTP_CONNECTION 'keep-alive' HTTP_COOKIE 'sessionid=noqontbtsr19k3oph2s0kkn61yxylhxi; fntreeSaveStateCookie=root%2Croot%2F202%2F208%2Croot%2F202%2F213%2Croot%2F202%2F208%2F210%2Croot%2F202%2F213%2F215%2Croot%2F53%2F60%2F129%2Croot%2F207%2F213%2F215%2Croot%2F207%2F218%2F220%2Croot%2F207%2F223%2Croot%2F207%2F223%2F225%2Croot%2F207%2F218%2Croot%2F207%2F213%2Croot%2F180%2Croot%2F180%2F186%2Croot%2F181%2F197%2Croot%2F53%2F60%2F105%2Croot%2F53%2F60%2F101%2Croot%2F1%2F6%2Croot%2F1%2F2%2Croot%2F10%2F26%2Croot%2F10%2F30%2Croot%2F37%2F39%2Croot%2F82%2F89%2Croot%2F53%2F60; csrftoken=Fb9x5rm1IUYRIa46yn0WVhF52N82SfgF' SERVER_NAME 'localhost' REMOTE_PORT '55789' wsgi.url_scheme 'http' SERVER_PORT '80' SERVER_ADDR '192.168.0.21' DOCUMENT_ROOT '/usr/local/etc/nginx/html' HTTP_CONTENT_LENGTH '300' HTTP_X_REQUESTED_WITH 'XMLHttpRequest' DOCUMENT_URI '/storage/volumemanager/' wsgi.input <flup.server.fcgi_base.InputStream object at 0x811495550> HTTP_DNT '1' HTTP_HOST '192.168.0.21' wsgi.multithread True HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded' REQUEST_URI '/storage/volumemanager/' HTTP_ACCEPT '*/*' wsgi.version (1, 0) GATEWAY_INTERFACE 'CGI/1.1' wsgi.run_once False wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x811824e10> REMOTE_ADDR '192.168.0.24' HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.8' CONTENT_TYPE 'application/x-www-form-urlencoded' CSRF_COOKIE u'Fb9x5rm1IUYRIa46yn0WVhF52N82SfgF' HTTP_ACCEPT_ENCODING 'gzip,deflate,sdch'
