I have over a few months (budget limiting) built up my first home office NAS and I thought I would list and show the finished machine.
For me the case was the most awesome part of the entire build. Its a small machine and space is limited so you have to be very careful of parts and size, but in the end the build quality and how it all fits in the case is just brilliant in my opinion. It is my first Lian-Li case, but I am now a big fan. I put in 3 drives as a start but there is lots of space for more as my needs grow.
I have big plans for this little box, as I get time I am doing more and more with it. The first priority was getting it to backup automatically all our client machines in the background using Rsync. For this one the Windows clients QtdSync came in very useful.
Getting started with a few Jails, DNS server, Owncloud, DB server, Web-server. The only part I am getting a little stuck with is my CIFS / Windows shares (will post later in new thread).
The only part of the spec I am not happy with and if I can afford it I would have changed is the fans, I had my eye on a few low power very silent fans from Noctua , but could not afford them.
Noctua NH-L9i, Noctua NF-P14 FLX (Intake 140mm), Noctua NF-S12B FLX (Outflow 120mm)
Later when I can afford it I also plan on looking at a Rikomagic and a Flymouse, running off a Plex Jail.
My biggest limiting factor at the moment is time to do all these cool things.
Basic Spec:
Basic Spec:
- PSU: 1x THERMALTAKE TOUGHPOWER ST 650W
- MB: 1x GA-Z87N-WIFI
- RAM: 1x 16GB 1600MHz DDR3 Non-ECC CL10 DIMM (Kit of 2) HyperX red Series
- HDD: 3x WD20EZRX - WD GREEN 2TB 3.5" SATA3 64MB CACHE
- CPU: 1x INTEL CORE I3 4130 3.40GHZ 2C SKT1150
- Case: 1x Lian-li pc-Q25 Blk cube
