john.doe79
- Aug 17, 2019
Hi there,
I already posted that, by mistake in the introduction area, but that was not the place to get feedback on my config ... apologies
My Synology DS415play does not satisfy my demands to PLEX any more, so I would need to get a new one. I build a custom PC for the same price as the DS1019+.
I do have:
and:
Once the 8TB from the USB is copied to the Raid-Z pool, I would like to have the 8TB as a single disk in the PC case (how to config/call that?). The data will then copied back to the 8TB disk. Once it is there, I would like to erase the Raid-Z pool and create a Raid-Z2 (or mirrored?) Pool out of the 3x 4TBs to have a data storage for my Pictures and Documents (off-site backup is provided in OneDrive).
The 2x 3TB I would also like to put in as a single drives: one will be the target of a DVR (network) and the other will host the Kids Plex library (moving from the 8TB, where currently are all the Plex Libraries).
The Corsair Force Series MP300 240GB, M.2 should become the drive where I host VMs (backing them up to the 3x 4TB (with redundancy) Pool).
Beside FreeNAS I would like to use some plugins/docker/VMs:
- processor: Intel Core i3-8300, 4x 3.70GHz, boxed
- ram: 2x Kingston ValueRAM DIMM 16GB, DDR4-2666, CL19-19-19 (KVR26N19D8/16)
- board: Gigabyte C246-WU4
- shiny case: Antec P101 Silent
- nice silent PSU: be quiet! Straight Power 11 450W ATX 2.4 (BN280)
- Some local flashy storage: Corsair Force Series MP300 240GB, M.2
I do have:
- 128GB Corsair Voyager GTX
- 256GB Corsair Voyager GTX
and:
- 3x 4TB WD Red
- 2x 3TB WD Red
- 1x 8TB Seagate (something, currently in a USB enclosure)
- plugin: Plex Media Server (Plex Pass)
- plugin: sabnzbd
- docker: unifi controller (later, when I upgrade my wifi/network)
- docker: pi-hole
- vm: Ubuntu (lab, learning)
- vm: Windows 10 Pro (occasionally testing)
- vm: pfSense (when the network is upgraded, will add a I350-T4 then to the PC)
