Moving disks around: Two questions
nycvelo
Greetings. I have two questions about disk upgrades to an existing TrueNAS system:
1. How to relocate a disk from one bay to another in an 4-disk raidz1 pool?
Backstory: A disk previously failed in bay 2 of this 8-bay system. The remote-hands service at my data center put the replacement disk in bay 6. Everything is resilvered and back up and running again, but I want to make room in bays 4-7 for a new raidz2 pool. Can I safely power down the system, relocate the new drive from bay 6 to bay 2 and resilver again? Or something else?
2. I'm looking to migrate my boot pool from two mirrored USB sticks to two NVMe SSDs. (Aside: Just because USB boot sticks work it doesn't mean you should use them, unless you like painfully slow upgrades and anything else involving operating system I/O.)
This older thread suggests the best way to do this is temporarily enable autoexpanding the pool and resilvering:
Is this still considered a best practice?
Thanks!
With the system powered down, move the disks as you please and boot, no need to resilver.
Watch out for differences in block size/ashift if you're mixing them in a mirror temporarily.
The best way to avoid that would be config backup, reinstall to NVME, restore config.
NVME (let alone 2 of them) is probably excessive performance for boot pool. You may not get what you're expecting in terms of an indestructible boot process unless your BIOS does the mirroring and allows booting/continuous operation from those devices.
rvassar
^^^^^ This.
Yes it's that simple. You can even move between controllers, within reason... Obviously you can't break the boot drive sequence.
The pool components are tracked by a form of UUID. It just ID's the drives and stitches the pool back together at boot time import.
