Philip Robar
- Jun 10, 2014
I spent a couple of hours trying to find an answer to this question via Google and was unsuccessful so I'm asking here.
On other operating systems like Windows, OS X, and (I think) Linux you can take an HD out of a USB case and connect it to an IDE (based on personal experience) or SATA (I think I've done this) interface and the drive just works with all of its data still intact.
Recently I tried to move a ZFS formatted 3 TB SATA Western Digital HD from it's (WD provided) USB3 case to SATA and neither FreeNAS 9.2.1.x, 9.2.2/9.3 nor 10 could not see the pool so as to import it--regardless of whether or not I exported the drive first. I.e. "zpool import" returns no results. (I was actually hoping that I wouldn't even need to export/import it.) Was I wrong in expecting this to work?
Here's my dmesg(1) output, filtered for what I think is the relevant stuff:
Drive in USB3 case:
Drive attached directly to SATA:
In case it matters the motherboard is an Intel DG41TY so it has an Intel® G41 Express Chipset, with:
• Intel® 82G41 Graphics and Memory Controller Hub (GMCH)
• Intel® 82801GB I/O Controller Hub (ICH7)
The USB3 card is a Bytecc PCIe BT-PEU310 using an NEC chipset.
Note: For the curious, this motherboard with an Intel Celeron 450 (64 bit Core architecture, not P4 era), USB3 card and HD in its USB3 case using just 4GB of non-ECC memory and the MB's Realtek RTL8111D Gb NIC have worked without error as a simple home file server (SMB and AFP) for several months. And just so I don't get slammed by the powers that be, I'm currently in the process of moving all of its data to "real" server hardware. It just would have been nice if I could have moved the drive from one interface to another instead of having to copy 6TB of data. (Once to another external USB3 drive--whose case I don't want to crack until I trust it enough to be sure that I don't need to return it--and then back to the original drive, now attached to SATA.)
Drive in USB3 case:
xhci0: <XHCI (generic) USB 3.0 controller> mem 0xd0600000-0xd0601fff irq 16 at device 0.0 on pci1 xhci0: 64 byte context size. usbus0 on xhci0 usbus0: 5.0Gbps Super Speed USB v3.0 uhub0: <0x1912 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 ugen0.3: <Western Digital> at usbus0 umass1: <MSC Bulk-Only Transport> on usbus0 umass1: SCSI over Bulk-Only; quirks = 0x0000 umass1:5:1:-1: Attached to scbus5 da1 at umass-sim1 bus 1 scbus5 target 0 lun 0 da1: <WD My Book 1140 1022> Fixed Direct Access SCSI-6 device da1: Serial Number 574343315430383235353235 da1: 400.000MB/s transfers da1: 2861556MB (732558336 4096 byte sectors: 255H 63S/T 45599C) da1: quirks=0x2<NO_6_BYTE> ses0 at umass-sim1 bus 1 scbus5 target 0 lun 1 ses0: <WD SES Device 1022> Fixed Enclosure Services SCSI-6 device ses0: Serial Number 574343315430383235353235 ses0: 400.000MB/s transfers ses0: SCSI-3 ENC Device
ada2: <WDC WD30EZRX-00DC0B0 80.00A80> ATA-9 SATA 3.x device ada2: Serial Number WD-WCC1T0825525 ada2: 150.000MB/s transfers (SATA, UDMA5, PIO 8192bytes) ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C) ada2: quirks=0x1<4K> ada2: Previously was known as ad7
