typeVOID
- Jul 6, 2015
all-
first off thanks for all of the help in the past and I apologize that this is my first noob post after 1.5yrs of using the forum as a great resource for my home diy nas server.
here is a quick run down of the system:
Asrock H67M-ITX mobo
Intel i3-2.6ghz
2x4gb ram
6x2tb WD RED drives ZFS5
recently I upgraded from 9.2.1.2 to 9.2.1.9 and that went without issue - I had an error that I was at 90% capacity and so I tried destroying a 2tb dataset which was older timemachine backups which had dedup on. This went on for a really long time and the server eventually became unresponsive. I rebooted and the system hangs at the "Mounting local file systems" prompt and stays there indefinitely.
I tried a fresh install on a 8gb USB and it will not auto-import the volume (says error has occurred) and then I tried restoring the config which replicates the same deal "mounting..."
There is no access to the nas from the network and the only thing I can get it to do is when you press ctrl+t you get a system process status.
Are there any troubleshooting techniques I should use / log files I should be drilling through. I have some linux experience but not enough to really diagnose an unresponsive system
Any insight would be awesome as there is some data that I would like to preserve - I have searched the forums but nothing that I have tried has worked and I do not want to destroy the data.
anthony
Intel i3-2.6ghz
2x4gb ram
anthony
